my oil return is kinda kinked , i/c piping issues
Old Sep 29, 2002 | 01:49 PM
TurbothisLS's Avatar
Default my oil return is kinda kinked , i/c piping issues
i'm using a -10 hose
it's kinda kinked because the oil pan i bought with a return fitting already welded is at a weird angle.
is this gonna be a problem?
it's slightly kinked in the middle.
also, i had to extend my ic piping to fit my pwr fmic. i used pvc pipe and pvc pipe hose/clamps..
will this hold pressure under boost?
Old Sep 29, 2002 | 04:06 PM
tony1's Avatar
Default Re: my oil return is kinda kinked , i/c piping issues (TurbothisLS)
Your piping might be alright but you need to fix the oil line. With the line being kinked like that it will cause the oil to back up into the turbo. This causes hot oil to sit in the turbo and you WILL have problems. Have the pan rewelded if you have to.
Old Sep 29, 2002 | 04:53 PM
Default Re: my oil return is kinda kinked , i/c piping issues (tony1)
so i can i drive on it for a little bit and then take it to get rewelded?
Old Sep 29, 2002 | 04:56 PM
tony1's Avatar
There is no way to say when it will do damage, but it's not good and should be fixed. If you have to drive it to get it fixed then I guess we'll find out. Drive it easy and try not to boost and it should help the oil stay a little cooler.
Old Sep 29, 2002 | 10:08 PM
turbo Si's Avatar
I had the same problem with a rubber return line. I went to a hardware store and bought a three-four inch spring to straighten out the line. Although this was not a permeanebt thing though. I bought another pan and used an fittings and steel braided lines. But I had white smoke up the *** coming out my exhaust. At first we thought it was the rings. Someone told me to take my intake pipe off my compressor housing and sure enough the lip of the compressor was all oil. luckily it didn't damage the turbo although atleast put a springin the line if you can till you get it properly fixed.
Old Sep 29, 2002 | 11:27 PM
Default Re: my oil return is kinda kinked , i/c piping issues (turbo Si)
hey, that's a good idea. i'll try that
Old Oct 6, 2002 | 07:48 AM
turbo Si's Avatar
So what happened? Did it work out for you?
Old Oct 6, 2002 | 09:55 AM
my manifold wasn't bolted up flush with the head and this caused the turbo not to spin and give boost, i haven't tried the spring thing, but i'm just gonna get the oil pan rewelded at the local muffler shop. (really close, i can walk there)
Jackzor
Jun 17, 2013 12:41 AM
DulinDragons
Oct 7, 2009 08:07 PM
mrlegoman
Jul 21, 2006 12:18 PM
scartail
Apr 16, 2005 06:06 PM
Ls1 FD3s
Mar 4, 2005 07:12 PM
