turbo install---> vacuum lines with a fitting on the turbo compressor housing
Old Sep 29, 2002 | 01:34 PM
TurbothisLS's Avatar
Default turbo install---> vacuum lines with a fitting on the turbo compressor housing
ok, i'm going to T off the brake booster line for the wastegate and T off the BOV and boost gauge at the FPR -> intake manifold line.
i'm not sure on the tial wastegate which line goes to the turbo and which goes to the brake booster line...
is it the top fitting for the brake booster and the bottom one to the turbo compressor housing?
please help, last part of my install
Old Sep 29, 2002 | 01:36 PM
falcongsr's Avatar
What is this crap?
Default Re: turbo install---> vacuum lines with a fitting on the turbo compressor housing (TurbothisLS)
put the turbo compressor line in the side(bottom) port, leave the top of the WG open.
Old Sep 29, 2002 | 01:42 PM
Default Re: turbo install---> vacuum lines with a fitting on the turbo compressor housing (falconGSR)
so just attach the vacuum line from the bottom wg fitting to the turbo compressor housing fitting.
no tapping of the brake booster line needed?
just leave the fitting off the top of the tial or install it and don't attach anything to it?
Old Sep 29, 2002 | 02:40 PM
falcongsr's Avatar
What is this crap?
yeah that will get you boosting safely for now at whatever boost level the WG spring is set for. you use the top hole with an electronic boost controller
Old Sep 29, 2002 | 04:55 PM
ok, can i adjust the boost on the wg?
Old Sep 29, 2002 | 06:52 PM
speedymon's Avatar
Is this better than having the side wg port attached to the brake booster? Quicker spool up?
Old Sep 30, 2003 | 07:31 AM
m R g S r's Avatar
Default Re: turbo install---> vacuum lines with a fitting on the turbo compressor housing (speedymon)
I'm wondering the ame thing...Will putting the side port of the WG to the compressor be beneficial in any way??
pjr710
Jun 8, 2008 11:48 PM
almostjdmeg
Mar 10, 2008 01:00 PM
b18_integra
Feb 18, 2008 04:42 PM
leinadmiih00
Jan 20, 2007 04:58 PM
the.hamburglar
Aug 1, 2005 07:27 PM
