switch for->Radio FM/AM antenna amplifier?????
Old May 1, 2011 | 10:41 AM
EG-SIXV-TEC's Avatar
Post switch for->Radio FM/AM antenna amplifier?????
i got a radio antenna amplifier for my car because my vx don't have the reg antenna and i want to keep the shaved oem antenna cover.
i installed it and want to put a switch on its power side or ground??
idk what brand it is.
I got a switch push on/off type from radio shack specs. Rated 3A at 125VAC, 1.5A at 250VAC.
Whats the average car radio antenna amplifier Will this switch works.
thanks in advance.
Old May 2, 2011 | 08:31 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: switch for->Radio FM/AM antenna amplifier?????
For any DC application, you can either switch the power or ground wire. On stealth fuel pump kill switches, I prefer to use the ground instead of the power wires. *** That switch you have should work without a problem.
jjos
Audio / Security / Video
Apr 26, 2016 02:09 PM
turbo-crx
Jan 9, 2009 09:58 AM
mrdeadman
Mar 15, 2006 08:02 PM
cyan1de
Nov 29, 2001 10:48 PM
yellow blur
Jul 11, 2001 11:01 PM
