Parting out 1995 Acura Integra DB GSR
Old May 1, 2011 | 07:54 AM
AlwayzSpoolin's Avatar
Default Parting out 1995 Acura Integra DB GSR
Just like the title says , Im starting to part out a 95 OBD1 GSR . The car is totalled and not salvagable at all , so dont ask for the shell. The car was hit in the front end. I will have the car back in my possesion in a day or 2 . The car is complete except for the front end as it is trash. But complete interior is their, suspension wheels, swap and all. As soon as I get the car back i will have pics up. If you need or want anything let me know. Also the car has black/grey cloth interior and exterior is white.
If you want parts let me know .
Also this same exact add will be going up on craiglist in charlotte, nc as well as on carolina hondas.com . The car is located in Concord/Kannapolis, NC 28083 . I CAN NOT ship parts at this time as I dont not have a car. You WILL have to come to me to get parts.
Any of the Carolina guys know whats up with carolinahondas.com ?
Thanks !
Old May 1, 2011 | 05:12 PM
Ballin_Ben's Avatar
Default Re: Parting out 1995 Acura Integra DB GSR
Full trunk interior?! PM me with price shipped to 29169.
Old May 1, 2011 | 08:00 PM
Yea i have all that , their is 1 cut on each of the side pieces where the rear struts are for a rear strut bar that I had in their. Other than that I have both side piecesand the cardboard piece that goes over the spare tire area.
But like I said before and if you had read what I wrote, I CAN NOT SHIP ANYTHING AT THIS TIME ! I DONT HAVE A CAR TO GET TO GET ANYWHERE ! IF YOU WANT SOMETHING, YOU MUST PICK IT UP .
Old May 1, 2011 | 08:11 PM
luvmihatch's Avatar
what u want for the blades picked up. in in charlotte so not far at all
Old May 2, 2011 | 03:02 AM
T9U4ReBgO's Avatar
What suspension upgrades does it have?
Old May 2, 2011 | 05:04 AM
tenedor sports's Avatar
mileage on swap and pm me a price complete...
Old May 2, 2011 | 07:49 AM
Their are no blades, never said that their was , 95's had fat 5's anyway .
Here is the suspension thats on it :
Cusco ST front strut bar - $125
Cusco ST rear strut bar - $100
M-Factory 19mm rear sway bar with 19mm prothane bushings and brackets - $125
Beaks Subframe kit -$45
K-Sport rear lower control arms - $100 ( bushings are all still good and intact )
Omni Power Front upper control arms with camber kit - $75
Koni Yellow SP3 Neuspeed edition shocks - $650 for the combo
-Neuspeed Race springs ( yellow )
-Ground Control bump stops
-Skunk2 Top hat bushings
OEM 24mm front swaybar with energy suspension sway bar bushings - $45
Carbing rear lower tie bar - $50
**NOTE** I'M NOT SEPERATING THE SPRINGS/SHOCKS , THEY WILL BE SOLD TOGETHER AS AN ASSEMBLED UNIT(S)
OEM front swaybar ( 24mm ) w/ Energy Suspension Bushings - $45
- OEM front swaybar ( 24mm ) w/OEM bushings - $35
- OEM rear swaybar ( 13mm ) w/all bushings, brackets and endlinks - $65
- OEM front Strut bar - $25
- OEM GSR THrottle body with all sensors - $75
- OEM DB8 muffler - $100
- OEM DB taillights , lightly smoked - $75
- REAR Disk swap , with everything you need and e brake cables - $250
- Front Disk setup complete - $75
- Black Cloth GSR front seats - SOLD
- Grey Cloth rear seats all 4 parts - $100
- Door panels with switches - $45 for each front and $30 for each rear
- 94-97 ITR replica front lip with OEM hardware and rivets, painted John Deere Blitz Black - $45
- OEM OBD1 Vtec injectors - $35
- OEM 98-01 CD player with pocket - $50
The swap is a 99 GSR Complete swap and has the following :
Milege - 130k
Wired for OBD1 and is running OBD2 injectors with clips .
Blox IM 1st gen
hondata IM Gasket
B16a2 Throttle body
P2R throttle body gasket
B16 Fuel rail
Energy Suspension Motor mount inserts
Energy Suspension shifter bushings
P28 ECU with a custom GSR map done by IH8RICRZ here on hondatech
NGK plug wires
New plugs ( 6 months old )
Will include a new timing belt as well with the swap, and the left side axle seal.
Will come with all acc. except the power steering pump.
Only thing that you will need , are axles. The axle carrier is still their and in good shape.
Tranny shifts smooth as butter
Have all paperwork to prove i am the original owner
If you need to know where , I am , look at my 1st post it will give my location.
Old May 2, 2011 | 07:59 AM
Also have a few other parts that I need to get rid of as well :
Tucked clutch line ( for integras only as it goes onto the T on the firewall ) - $40
Arizona racing B -series cam seal BNIB - $30
Omni power 2.25" adjustable test pipie, used for 4 months - $75
RS Machine Half sized dual core polished alum radiator, outlets are for B-series hoses , used - $100
B&M Adjustable fuel pressure regulator , used - $30
94-97 USDM ITR poly front lip painted John Deere Blitz Black , will include 8 large size rivets, and the bumper clips and nuts. But you will need brackets for the lip to secure to the bumper and can be had at local auto store like ACE HARDWARE. - $45
Ill have pics of everything up shortly .
Old May 2, 2011 | 08:12 AM
**NOTE** GC top hats and fuel rail are not available, so DONT ASK !
OBD2 P72 '99 GSR VTEC Head , complete with all sensors , vtec solenoid, dizzy, NGK wires, AR Black cam seal and valve cover. NO Intake manifold, NO injectors and No fuel rail ! Those have been sold and will not come with the head. $600
OBD2 P72 '99 GSR Block , complete with everything. All sensors, brackets, clutch and flywheel . Will include new timing belt and oil pan gasket. $400
Energy Suspension Motor mount inserts and Shift bushing inserts - $60 for all !
P28 ECU Chipped w/GSR map. Setup for Intake , Header, Exhaust, and Intake manifold. With advanced timing and ignition maps , more aggressive fuel maps. Will also come with a 2nd chip , which is a race setup. Vtec @ 5200 and redline at 8500 , 2nd chip , VTEC @ 5300 and redline @ 9200
$140
EVERYTHING IS PICK UP ! I WILL NOT DELIVER AND I WILL NOT SHIP ! I CANT MEET UP WITH YOU OR ANYTHING ! I HAVE NO CAR ! SO DONT ASK !
Old May 2, 2011 | 11:18 AM
Ballin_Ben's Avatar
Pm'd
Old May 2, 2011 | 12:52 PM
Replyed ! People please read above ! Im tired of saying this over and over again !
I CAN NOT MEET UP WITH YOU , I CAN NOT DELIVER, I CAN NOT SHIP ANYTHING TO YOU ! I HAVE NO CAR AT ALL ! IF YOU WANT PARTS , YOU WILL HAVE TO COME TO ME ! END OF STORY !
Old May 2, 2011 | 05:14 PM
Salami's Avatar
PM sent.
Old May 3, 2011 | 06:33 AM
replyed ! Tuesday morning bump !
Old May 3, 2011 | 07:28 AM
Thrule01's Avatar
did i miss a price for the swap?
and price on koni yellows?
Old May 3, 2011 | 08:05 AM
If you want a price on somthing, pm me .
Edit - Prices are posted !
Im not seperating the spring/shock combo . Selling as a full assembled unit !
Old May 3, 2011 | 08:15 AM
Thrule01's Avatar
took you just as long to type it here as in a PM...never mind then..buddy just needs konis
Old May 3, 2011 | 02:08 PM
Oh well ::shrugs::
Let me know if he changes his mind . He could take it all apart himself and make some of his money back.
Old May 4, 2011 | 05:59 AM
Wednesday morning bump
Old May 4, 2011 | 03:07 PM
Just got done stripping the interior . If their is anything you want , let me know . Next few days i will be stripping the rest of the car and it will be gone with a week or 2 tops !
Old May 4, 2011 | 06:22 PM
_SHIFT's Avatar
pm'ed
Old May 5, 2011 | 05:55 AM
replyed ....... Thursday morning bump !
Old May 6, 2011 | 04:26 AM
Friday morning bump !
Old May 6, 2011 | 06:04 AM
Salami's Avatar
Please give me a call so we can get something worked out so I can get those parts from you.
Thanks
Old May 6, 2011 | 07:21 AM
I'll call you when I know ill be home , im out of town right now. I wont be back until sunday.
Old May 8, 2011 | 06:43 AM
Sunday morning bump ! Come get parts !
