What is everone using for cutting fluids?
Old Apr 30, 2011 | 02:55 PM
Fabworx's Avatar
Default What is everone using for cutting fluids?
Were looking to purchase a new batch of cutting fluid and was wondering if you machining guys could put your knowledge here, thanks in advance!!
Old Apr 30, 2011 | 03:00 PM
1.5Slowmatic's Avatar
Default Re: What is everone using for cutting fluids?
at my work we use rustlick 250r in all the machines. seems to do a great job. a skimmer would be a great saver of the coolant itself. although the machine i run is horribly overdue for a change the oil needs to be skimmed off about once a week by hand because we have no skimmer for some unknown reason on it.
Old Apr 30, 2011 | 03:07 PM
Fabworx's Avatar
That's really what im trying to avoid, it leaves behind such a mess, Im looking into the rustlick WS-5050 if anyone has experience with it?
Old May 1, 2011 | 06:07 AM
EGJDM's Avatar
You should look at either hangstefers or trim cutting products. both work really well.
Old May 1, 2011 | 10:50 AM
SLMachine's Avatar
OG Fabricator
Run Hangstefers here and have had good luck w/ it. Best of all it doesnt have a nasty stinky like some other coolants.
Old May 1, 2011 | 12:01 PM
CRMB's Avatar
OG Fabricator
We run 76 Koolkut II HD. Nasty **** that will cause rashes on your arms if you get it on your sleeves. Works really well though.
Old May 1, 2011 | 01:48 PM
i know on the machines that actually have had it changed recently they only have to vacuum off the scum and oil once a month about or so. the issues with mine is its 150 gallon tank so changing it is quite involved hence the 2 year period since the last change.
Old May 2, 2011 | 11:00 AM
Fabworx's Avatar
Thanks everone for you input!!
turkeyslow
Welding / Fabrication
Apr 3, 2013 06:27 PM
punkinbeck
10
Jan 26, 2010 11:43 AM
hondaapi
Aug 26, 2007 07:37 PM
Turboredteg
May 6, 2006 01:30 PM
ProEater
Feb 19, 2004 08:06 PM
