best fluid for ccíng heads
As the topic sais....
water is bad ... too many bubbles under the glas
water wit a little soap ... better but also not very good
Any ideas ?
Any ideas ?
Re: (SwappedTURBOegg)
why would it be dangerous? its gasoline. They let every idiot with a vehicle in the world handle it so it cant be that risky. unless you accidentally atomize it into a closed container with oxygen, then light it..then you might have a problem.
Re: best fluid for ccíng heads (hondaapi)
Marvel mystery oil works well.ATF will work good to.If you have a glass burret windshield washer fluid will work but don't use it with an acrylic one because the alcohol will crack it.
