Blackworks Coilovers - rear not low enough
Just installed some blackworks coilovers in my 09si sedan. everything bolted up fine, but im still getting about a 2 finger gap in the rear. the spring is set to its lowest height. was i supposed to remove the "cone shaped factory upper spring pad?" Do i need to let the springs settle? has anyone had an issue with their rear not being low enough? help is much needed!
Did you clock the suspension bushings to the new ride height?
zcivicz
11
Aug 27, 2002 12:44 PM
