Suspension & Brakes Theory, alignment, spring rates....
f&f type 1 question
Old Apr 29, 2011 | 08:57 PM
parrotcrx's Avatar
Default f&f type 1 question
so im getting f&f type 1's in the next couple weeks and im debating on either getting the eg ones or the ef ones, what would be the advantages and disavantages of each.
im wanting to slamm it and some auto x this summer, and yes ill raise it to auto x
thanks for your input in advance
Old Apr 30, 2011 | 09:50 AM
STOCK_SOHC_DX's Avatar
Default Re: f&f type 1 question
If you are going to auto-x your car don't get F&F's there are better options.
Old May 1, 2011 | 02:05 PM
batallic's Avatar
if u want a cheap set up, get progress but way better quality
Old May 1, 2011 | 02:31 PM
99blackcivicSi's Avatar
having had f&f type 1 on my daily driver for a year they are a great street coilover that gives a good ride slammed it ends there
Old May 1, 2011 | 07:48 PM
jaggin23's Avatar
getting type-1's for my daily, but idk about for an auto-x setup
Old May 2, 2011 | 04:22 AM
Libertariat's Avatar
Ek Forever y0!
These must be 16 year olds who have no idea what ride comfort is to say "yeah dey ride slamd and i wouldn't have it any other way"
It is impossible to ride "slammed" and have a remotely good ride. To not bang your suspension components and destroy your bushings you need really stiff rates, 500+ Front and I'm sure at least 350lb springs in the rear. Not to mention having to drive carefully over every dip in the road or uneven surface.
Old May 2, 2011 | 05:13 AM
well your full of ****.....
i'm not 16 actually i'm 26....would you like me to rephrase this? they ride GOOD for a slammed car....considering all my bushings have been replaced and i do NOT smack my upper control arms on the shock towers.
On the highway they ride very cush does not beat you to death. don't be an ***
Old May 2, 2011 | 07:33 AM
civexspeedy's Avatar
For street or autox use, don't get these. If you plan on doing a few autox's a year, definitely don't get these. Also, every time you adjust your ride height, you'll need to get an alignment. Either slam it and stay slammed, or leave it at a reasonable height and enjoy the comfort and the true performance of your suspension.
Go with Koni/GC.
Old May 2, 2011 | 02:51 PM
T_S_S's Avatar
The ST Suspensions are tuned by their German engineers. They can perform very well on the track and daily street use. The price is very reasonable. The quality is by far better than others as ST Suspensions is the brother company to KW Suspensions. If your looking for a coilover with full adjustment then I would recommend the KW coilover but the price is much higher.
Old May 4, 2011 | 08:18 AM
opc's Avatar
opc
if its a coilover and not something from a brand over 10 years old.. stay away.
Old May 8, 2011 | 11:35 AM
94VTEC2TONE's Avatar
i just got a set cant beat the price, i guess well see how they hold up, i had great customer service from weaksauce vendor and the product seems to be put together well imo, see if it does well on street this summer
Old May 8, 2011 | 01:03 PM
Ek Forever y0!
It's getting pretty old that you just tout the suspension you sell when it has almost no following whatsoever in the Honda community.
The price is terrible, $800 for a coilover set that doesn't have adjustable damping, terrible spring rates, (300lb/100lb as you mentioned in your info thread) a 5 year warranty, and as mentioned hardly any Honda following.
For the same $800 you can get Koni/Ground control, which has the largest following of any suspension setup and has a large following on many car makes. Easily the largest aftermarket shock manufacturer by volume in the world. You get a lifetime warranty, you can pick your rates, the shocks are re-buildable to handle higher rates, and the damping is adjustable.
Sorry, for $800 the ST setup really can't compete for what is offered for Hondas already. Progress CS-II at $580 is better than the ST $800 coilovers. At least with the progress kit you get a manufacturer with a long following, record holding products, and you can choose spring rates.
Everything about the ST setup you've mentioned so far only tells me that no one in the company has ever taken a basic economics course.
Old May 9, 2011 | 09:30 PM
Listen to these guys, they are the best for the $$. Here's a great example
http://htarchive.org/showthread.php?t=2580743
Old May 11, 2011 | 10:33 AM
chrispyFTW's Avatar
They ride pretty nice even all the way down. It's good that they're shock length adjustable.
EK9 CTR
Suspension & Brakes
19
Aug 6, 2015 12:49 AM
on-site ej1
Suspension & Brakes
14
May 3, 2010 03:13 PM
dc5-r_0144
Feb 15, 2008 04:46 AM
Mr. Samurai
Jul 24, 2004 01:15 AM
