b18b1 ls vtec has an idle problem!!
Old Apr 29, 2011 | 07:45 PM
B18_badboy's Avatar
Default b18b1 ls vtec has an idle problem!!
Hey there.. Okay well I just bought a a 92 civic hatchback and it's got a b18b1 ls with vtec. Well my problem is it doesn't idle under 1000 rpm's and once it's warmed up it idles from about 800 to 1400 rpm's.. Doesn't anyone know what it is or mite be that's not working right? Thanks alot!!!
Old Apr 30, 2011 | 04:24 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: b18b1 ls vtec has an idle problem!!
Check your IACV. Are you saying the idle surges between 800 and 1400 rpms?
Old Apr 30, 2011 | 07:00 AM
B16aEk4drbeater's Avatar
theres a screw hole right by your throttle body,, try turning that down first before doing the Iac,, if the idle is set too high,, it makes your engine surge up and down like what its doing now... the screw hole is on top of your tb and is adjusted with a flathead..
Old Apr 30, 2011 | 10:38 PM
B18_badboy's Avatar
Thanks guys! It runs great now!!!
Old May 1, 2011 | 07:08 AM
so what was wrong with the car?? idle set too high or bad iac?
Old May 1, 2011 | 02:40 PM
B18_badboy's Avatar
Yes. The idle was way to high! Turning the idle down fixed the rpm jumping from 800 to 1400 rpm's.. But it still not idling under 1000 rpm's!! I thought it fixed it but it's still idling at about 1,100!!
Old May 1, 2011 | 02:41 PM
B18_badboy's Avatar
Also the guy I bought the car from said it hard a " 1000 rmp stall on it",is there even such a thing? Ive never heard of that!!
Old May 1, 2011 | 04:43 PM
hmmm,, next thing to check,, the throttle cable... put your foot UNDER the throttle and push upwards,,, just in case you have a too tight cable,, your idle will drop if you put the throttle pushing towards you...
Azad_R
Oct 2, 2013 07:54 AM
BseriesEG
Sep 6, 2008 10:07 AM
efyou
Apr 18, 2007 06:00 PM
dangrass
Aug 6, 2004 06:50 AM
