knock sensor
Old Apr 29, 2011 | 04:21 PM
runnyray's Avatar
Default knock sensor
i have a 99 coupe with a d16y7 block which is non vtec and a d16y8 head which is vtec and the d16y7 block dont need a knock sensor but the d16y8 head does need a knock sensor what can i do to resolve this problem also the car is running on a stock ex ecu and wiring harnest which is vtec??????????
Old Apr 29, 2011 | 04:50 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: knock sensor
There's a threaded hole on the Y7 block since the Y8 shares the same block. So get a knock sensor and wire it to the P2P ECU. You can use a knock sensor from any B series VTEC OBD0/1/2, D16Y8, H22 OBD1.
Old Apr 30, 2011 | 04:53 AM
runnyray's Avatar
i got the knock sensor i just dont know how to wire it what color is the wire
Old Apr 30, 2011 | 07:32 AM
Technical Hero
You'll have to wire it from the sensor to C3 on your ECU harness.
jarhead90crx
May 10, 2011 01:06 AM
s_vares
Sep 3, 2006 02:54 PM
THC07
Oct 2, 2005 01:31 PM
redpeppers
Sep 15, 2005 06:42 AM
MurphDog74
May 24, 2002 08:39 PM
