can b18c rods be used in b18b1 engine??
Old Apr 29, 2011 | 02:43 PM
speedciv's Avatar
Default can b18c rods be used in b18b1 engine??
i dont know if this is the right place to post this but i am..lol im looking to build up my b18b1 im doing an ls vtec and i am boosting the compression ratio to around 11.7-12.1 and want to put forged rods in the car and i was wondering if b18c rods will work i no they are a little longer and i just wanted to make sure before i bought them
thanks
Old Apr 30, 2011 | 08:07 AM
BoltonGSR's Avatar
Default Re: can b18c rods be used in b18b1 engine??
If you put GSR rods into your LS engine it wouldn't be an LSVTEC. GSR rods have a smaller stroke for top end revs. LS have a longer stroke for more torque.
Old Apr 30, 2011 | 08:28 AM
el crapitan's Avatar
stroke is determined by the crank. not rod length
Old Apr 30, 2011 | 08:32 AM
b00stedOne's Avatar
im pretty sure if you use gsr rods, you need to use the gsr crank too.
Old Apr 30, 2011 | 01:21 PM
C-Rex1021's Avatar
stroke on the LS crank is longer than GSR. I don't think it'll work.
Old May 4, 2011 | 01:21 PM
speedciv's Avatar
thanks
Old May 6, 2011 | 10:04 AM
GSR.BoostedB18C's Avatar
They are correct you must use the rods/crank together. The length is different on those rods. GSR is 5.433 rods LS/B20 5.394 Use the GSR rods and LS crank and be ready to hear those pistons crash the head!!
Old May 6, 2011 | 10:24 AM
m_shake's Avatar
don't forget that the gsr big end is narrower then ls aswell
Old Jun 22, 2013 | 11:15 AM
Stevenpace's Avatar
Ok I have an ls vtec swap that bore over n some things done to it.. One question, are the stock b1 internals forged? Because I know my crank is stock, but I have forged rods, I don't think there were any markings on them, def. not gsr rods.. R the stock b1 rods forged or no?
liquidrider
Dec 7, 2009 04:07 AM
hotrod99
May 3, 2007 06:11 PM
Rhymenoceros
Apr 14, 2006 06:18 PM
TurboEH2
Apr 2, 2005 11:15 AM
B18
Feb 13, 2002 11:59 PM
