Boosted civic bogging at low rpms.HElP
Old Apr 28, 2011 | 11:39 PM
Tizzbert's Avatar
Default Boosted civic bogging at low rpms.HElP
Hey fellow hondaneers. I got a problem that no one seems to have a solution for.
I have a boosted civic 4 door that is bogging at low rpms only, and seems to be wasting more gas. Once my roms climb to about 3000 car drives smooooooth, only bogs low in 2nd if I shift slowly to 2nd. Ive replaced the spark plugs and have new noligy hot wires. Ive noticed on my air fuel ratio gauge that when im below 3000 rpms or so it reads 17-18 when normally its about 13 to 15 and 11 to 13 when hitting boost. Car isnt tued only by comouter by the ex owner. Ill lust all my mods below thanks!
ENGINE: y8 block. 020 over, vitara 8.5:1 pistons, egal rods, cometic head gasket, Arp head studs, king race bearings(mains and rods), full port and pollished on y7 head, accel ign.coil, noligy hot wire.
TURBO: : TD04L from a WRX, oil, and water cooled. Custom manifold setup. 3" turbo-back stainless steel exhaust, HKS blow off valve, 38mm external wast-gate(piped into down pipe) external wast-gate(piped into down pipe)
ECU: : factory ecu with aem fic piggyback computor, (no check engine light) aem wideband 02 sensor,and controller dsm 450cc injectors,walboro 255 fuel pump,d
Old Apr 29, 2011 | 03:15 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Boosted civic bogging at low rpms.HElP
So what did the former owner have to say about it?
Old Apr 29, 2011 | 04:56 AM
apexi_rsx's Avatar
all i gotta say is those nology hot wires are JUNK. the ground straps go to shyt and they fall apart in just over a yr or 2. ive had them before and they were not made to par. seems ur leaning out quiet a bit. is ur air cleaner cloggin up the turbo?
Old Apr 29, 2011 | 05:22 AM
The Grumpiest
How about getting a real tune?
Old Apr 29, 2011 | 06:00 AM
ekracing's Avatar
check for boost leaks your afr seem lean, and ya, you need you get a good tune.
Old Apr 29, 2011 | 06:08 AM
The Grumpiest
Yeah. 17-18 is super lean.
Old Apr 29, 2011 | 07:20 AM
lunareg's Avatar
^this
and Oem wires for god sakes.. those other wires blow ***
Old Apr 29, 2011 | 11:25 AM
Tizzbert's Avatar
If the air cleaner to turbo was clogged. That would cause bogging? Wven tho once in boost its fine?
Old Apr 29, 2011 | 11:27 AM
Tizzbert's Avatar
Yea this is probably the best idea. Its just money is hard to come by right now and I need a clutch because its slipping so I have to make that my priority.
Old Apr 29, 2011 | 11:30 AM
Tizzbert's Avatar
He said it just needed a tune. He said he never had the problem before. Bit I mean ppl lie so who knows
Old Apr 29, 2011 | 11:32 AM
Tizzbert's Avatar
Originally Posted by lunareg
^this
Any certain wires I should get
Old Apr 29, 2011 | 11:34 AM
Tizzbert's Avatar
Thanks for help guys.. My car has high pitential if only I could fix this then I can focus on the body. So all advice is appreciated
Old Apr 29, 2011 | 01:00 PM
apexi_rsx's Avatar
if its laggin and not boosting as quickly u probably have boost leak. if the inducer can not pull as hard it will make it hard for the turbo to breathe and work harder to achieve the desired psi.
Old Apr 29, 2011 | 03:30 PM
lunareg's Avatar
the ones from honda ie:OEM
do not boost that damn car if it hasnt been tuned, your going to fry the rings, if they arent already..
Old Apr 29, 2011 | 03:36 PM
Tizzbert's Avatar
Wheres first place I shoyld check for a boost leak
Old Apr 29, 2011 | 03:37 PM
The Grumpiest
Intercooler. All couplers.
Old Apr 29, 2011 | 06:07 PM
2000siem1's Avatar
^ yea that
Old Apr 29, 2011 | 10:04 PM
virgineg6's Avatar
try posting in the forced induction section also
Old Apr 29, 2011 | 10:26 PM
Tizzbert's Avatar
Old Apr 30, 2011 | 07:02 AM
B16aEk4drbeater's Avatar
really sounds like you need a tune.....
hondacrx0991
Jul 21, 2013 09:47 PM
elliott_holtGSR
Oct 13, 2010 06:01 AM
b00stedOne
Jul 5, 2010 03:29 PM
LsVtecCoupe00
Feb 5, 2007 08:31 PM
fush
Dec 26, 2002 02:41 PM
