Transmission & Drivetrain Gearboxes, Differentials, Clutches
B Series Differential Bearing Failure - Pics Inside
Old Apr 28, 2011 | 10:08 PM
Beckerton's Avatar
Default B Series Differential Bearing Failure - Pics Inside
Well, long story short...The car made some knocking sounds about 1500 feet from work the other day. Pulled it into the parking lot, worked my day away and when I came out to head home the sound was no longer there.
Fast forward about a week later...
Driving the car from the mall to home and I notice n intermittent high pitched whine. About 10 minutes later I can smell burning oil...I immediately think it's the backhoe in front of me struggling up the hill. I think to myself "thank God my car doesn't burn oil..." Then I look into the rear-view to see a huge cloud of blue smoke following me. Pull into the driveway and realize I have leaked some sort of fluid all the way up the driveway. Jack the car up onto axle stands, crawl underneath and discover I am leaking oil from my tranny seal, intermediate shaft side. Go to Honda, order seal, wait for seal.
Fast forward to today...
After work I jacked the car up onto axle stands and have at it...
I work my way through removing nuts and bolts and get the intermediate shaft out of the way. Pop the seal out and that's when I realized I had bigger issues on my hands than just changing a seal.
Hmmm...missing some ***** for this bearing...
Not even sure what this collar-type thing does, but it looks pretty chewed up
What I found of the now non-existent bearing
These words have never been more true...
And this pretty much sums up how I feel
So at this point, I'm thinking I will just pickup a limited slip transmission. My throwout bearing makes noise every now and again, and 3rd gear has a dirty grind so this will be a good opportunity to have a low mileage LSD setup installed.
Moral of my story...if your transmission starts making noise, and then leaks oil like a bastard, you have your work cut out for you...
Old Apr 28, 2011 | 10:10 PM
Beckerton's Avatar
Default Re: B Series Differential Bearing Failure - Pics Inside
Holy high hell these pictures are huge...sorry guys!
Old Apr 28, 2011 | 10:22 PM
Linked's Avatar
i would love one of those stickers man, holds true in every uniiversity town where kids are driving new GTOs and camaros
Old Apr 28, 2011 | 10:37 PM
Beckerton's Avatar
I have a couple more kicking around somewhere...PM me...
Old Apr 28, 2011 | 10:55 PM
blackedEk's Avatar
do u usually beat on the car
Old Apr 29, 2011 | 07:28 AM
civicsmoke's Avatar
that sucks but on the other hand paradise blue green pearl ftw!
Old Apr 29, 2011 | 07:50 AM
94EG8's Avatar
Seagull Management
Moved to transmission and drivetrain for better responses.
Old Apr 29, 2011 | 08:04 AM
slowcivic2k's Avatar
Looks like you regularly dump the clutch, diff bearings generally do not just blow up. Pull it apart and make sure you didn't break anything else or fatigue/crack the casing.
Old Apr 29, 2011 | 08:09 AM
94EG8's Avatar
Seagull Management
I'd hazard a guess that the final drive is probably toast. If it wasn't popping out of 5th from lack of fluid yet the gears might be ok.
Old Apr 29, 2011 | 11:26 AM
Beckerton's Avatar
I might have dumped the clutch 20 times since owning the car.
It has never popped out of any gear, but did have a slight 3rd gear grind that developed progressively worse since I have owned the car.
I'm going to pull the tranny and have it swapped with a Limited Slip setup.
DonAlex2
14
Sep 29, 2011 02:04 PM
bmxkills
24
Jan 23, 2011 08:12 PM
scartail
Dec 17, 2006 03:25 PM
EFresh
Jul 31, 2006 01:44 PM
ItrpwrdCrx
Sep 13, 2004 12:00 PM
