b16 woln't start
i put a jdm b16 in my 92 civic cx and i cant figure out why it woln't start i check the engine harness plugs it has spark and it has fuel it cranks over but woln't fire and iam using a p30 ecu if that makes any diffrence thanks
so out to the car i took the spark plugs out and dump a lil gas in the cylinders and i started right up so i played around with the injectors i put 2 diffrent set in and nothing but i am getting fuel in the fuel rail could the fuel pressure regulator be bad PLEASE HELP
check ignition coil
check grounds
check if fuel pump is priming
skUnK2jdm
16
Feb 10, 2007 02:43 PM
chirp2hrd
Jun 8, 2003 03:15 PM
