Honda CR-V & Element 2WD & 4WD Element & CR-V
98 CRV Burnt Valves
Old Apr 28, 2011 | 11:13 AM
spyder98's Avatar
Default 98 CRV Burnt Valves
I have a 98 CRV with around 160k miles I have the P0303 code and have burnt valves ive been driving the car like that for 9 months no money to fix it right now My question is can i change the head with out removing the timing belt?
Old Apr 28, 2011 | 12:19 PM
INVN01's Avatar
Default Re: 98 CRV Burnt Valves
That shouldn't be a problem. The timing belt has to be removed from the cam gears but doesn't have to be taken completely off. I would personally recommend that you change it if it hasn't been changed already, but that is your decision. Changing the water pump is also a good idea too while you are at it. It's just general maintenance that is easier to do while things are already apart.
Old Apr 28, 2011 | 12:44 PM
spyder98's Avatar
At first I wanted to replace the motor with one from hmotorsonline but no money at this time. Like i said ive been driving it with bad valves for 9 months so i dont want to waste more money then i have to incase it doesnt work it. If it works ill go ahead and replace both timing belt and wp. Im getting a head for $40 wit 110k miles im taking it to the shop to get the heads brushed then just install it myself. Anything specific things i need bolts? gaskets? Do i need to mess with timing? or position of the piston?
Old Apr 28, 2011 | 07:06 PM
INVN01's Avatar
You WILL need a new head gasket. I would recommend ARP or Golden Eagle head studs as stock ones can stretch out during removal. As far as position of the piston, you need to get a Haynes manual. You ALWAYS put #1 piston at TDC and then cam gears have a lock pin location to keep them from moving while in the proper position.
Old Nov 28, 2011 | 07:55 AM
spyder98's Avatar
I ended up having the whole complete motor rebuilt. and its running perfectly now. Thanks for your help "INVNO1"
Old Dec 1, 2011 | 03:07 PM
FourthGenHatch's Avatar
I was going to say if you want to clean valves on the cheap look for this stuff called Top Engine Cleaner. I have seen it from the GM dealerships but we use it on all kinds of stuff at work. Basically you pull off a vacuum hose and stick it in the bottle and suck up this liquid from the bottle. Then shut the engine off. Let it sit in there for a while. Whatever that stuff is it is nasty. Eventually you start it back up and let it run and white smoke billows out for a while but eventually it burns off. It has saved a couple junkers at work from the scrap heap for a cheap fix.
Old Dec 5, 2011 | 11:45 AM
spyder98's Avatar
I wish it would of been that easy...The motor just needed to be rebuilt or replaced.
ajth87
Jul 13, 2006 02:18 PM
b20vtecv8killer
Aug 29, 2004 07:53 AM
radzer0
Mar 29, 2004 04:48 AM
311
Jul 20, 2002 10:08 AM
g35driver
Feb 28, 2002 11:35 AM
