Grease - What to use for windows and seals on Del Sol?
Hi freaks :-)
Hondas own Shin-Etsu Grease is discontinued (at least where I live, Europe).
What do you guys recommend as a substitute to use my Del Sol? Can I use Loctite 8104 for instance?
My planned usage is for two things:
1) The Power window rails to fix jerky movement.
2) The precious and most expensive seals on the A + B column to prevent them from drying out and avoid squeaks and leaks.
For the rubber seals on the columns and roof, I use something called "Gummi Pflege Stift" which is german for "rubber care stick". The manufacturer is einszett.
I would just use synthetic grease for the power window rails.
I found the original grease at a shop in the UK - 40$ for 100g.
http://www.chilternconnections.co.uk...roducts_id=199
Too expensive though, so I ordered it from the US - 16$ for 100g
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=380280427509
Thanks guys :-)
Thanks guys :-)
