Del Sol window problem?
My del sol windows all work great, but the passenger side one seems to struggle when it rolls up, I am not sure why or what is causing it, but it goes, then slows down, then speeds up, slows down and then goes up to the end... kinda weird... anyone have any ideas?
Re: Del Sol window problem?
Your window motor is probably just getting old. They tend to slow down with age. All of mine are slowing down a bit. The driver's side one does exactly as you describe, I assume because I use it the most. Greasing the side tracks might help. I forget which grease would be good to use without leaving alot of residue/streaks on the glass.
'Honda Shin Etsu' for the seal works wonders.
A quick Google for 'Honda recommended lubricant list' will net you another site with a fine list including part numbers - G'luck :-)
What part is this?
