Triple row JVT aluminium radiator install DB8
Old Apr 27, 2011 | 11:20 PM
CaliforniaDad's Avatar
No-Traction = Fun
Default Triple row JVT aluminium radiator install DB8
Today I noticed a slight coolant smell from under the hood. I pop'd the hood and look what I found......about a 6" crack in the top of the radiator. So went out and picked up a triple row full radiator and swapped it out. Nothing crazy just thought Id post it. The radiator fit-meant was EXCELLENT A+
A big thanks goes out too PowerHouse in victorville CA (Thanks Javier)
I used a mix of 60% water and 40% coolent + 18 cap fulls of the water wetter. Also installed my 12+ slimline fans. It might work too well as it never got hot enough to even turn the fans on.
Just some random shots...Enjoy
Old Apr 28, 2011 | 06:02 AM
fcm's Avatar
fcm
Old Fart
Default Re: Triple row JVT aluminium radiator install DB8
I had the same "problem" when I installed my triple core rad, [not reaching proper running temp.] I switched out my thermostat to a "hotter" one, problem solved. 94
Old Apr 28, 2011 | 07:28 AM
No-Traction = Fun
Hey FCM, happen to remember what temp it was? I'm going to install my turbo motor in a month or so....should I just leave it as is, since ill generate more heat going FI.
Old Apr 28, 2011 | 12:39 PM
racebum's Avatar
i would, wait till the turbo is in and you tune before you address anything. if you don't mind use your camera skills on the install. i'd like to get at least a few cars {including mine} indexed on turboinstall before the end of the summer.
by the way, can i use those pics of yours for a drive axle article? you did a really good job with the layout
Old Apr 28, 2011 | 04:07 PM
No-Traction = Fun
Sure more than welcome to! need me to email them or can you just grab them off the site.
DG
Old Apr 28, 2011 | 04:25 PM
fcm's Avatar
fcm
Old Fart
I agree, wait until you do the turbo swap and tune, then if you need to switch the thermostat, do so.
Sorry it was 5 years ago I swapped out the thermos, I can't remember what temp it was, I just asked for the next one up. 94
Old Apr 28, 2011 | 06:12 PM
racebum's Avatar
DG
pulled em off the site, i'll pm you a link to the completed article when i finish it
Old Apr 28, 2011 | 07:52 PM
No-Traction = Fun
Sweetness!
fatman69
Dec 3, 2007 06:36 PM
lke2drvgsr
Aug 27, 2004 09:01 PM
__37__
Jul 7, 2003 05:58 PM
xrocket21
Jul 1, 2003 04:52 PM
Julian
Jul 25, 2002 10:23 AM
