Alaniz Comp Gsr Head Built B20z Block B16 Trans etc
Old Apr 27, 2011 | 09:05 PM
negroeg6's Avatar
Default Alaniz Comp Gsr Head Built B20z Block B16 Trans etc
Call or text 916-384-8734 all parts r located in sacto,ca no trades im getting out of the game all parts r new and have 1,600 miles on them pics of block and head will be up soon anything else u might need i might have just ask. thanks for your time and viewing my post...
Alaniz Competition Gsr head 1,600 miles on rebuild skunk2 dual valve springs, crower tit retainers, bronze valve guides, new valve seals,blox pro 1 cams with adjustable cam gears, new oem vgsr valves,vtec syl, clean black b16 valve cover with oem type r washers and spark plug cover. Pics will be up soon im taking kit to the machined shop to get cleaned up tomorrow. $1500 I still have the blox box for the cams with the paper work Head is stamped the nuts for int mani and ehx mani r included
B20z block 11:5: CP pistons Eagle rods z10 block girdle moroso oil pan oem itr oil pump ctr crank pulley new water pump and timing belt arp head studs new alternator with new belt acl race bearings 10 lb xtd fly wheel with stock exedy clutch . I still have the cp pistons and eagle rod box's too. Pics will be up soon
$1500
00 SI tranny shifts like butter no vin with HAP stamp on transmission an i still have the reciept in hand with my name and info on purchase. $700
OG gsr skunk2 manifold blox 68mm throttle body port matched to int manifold all sensors attached RC 310 injectors itr fuel rail with silver aem fpr itr throttle bracket $600
Gold JDM b series shift linkage $120
HOndata s300 p28 $550 I have box and software with usb cord
B serie tri Y headers (custom cut shown in pic #2 so u could slam your car and it wont scrape) with blox 2.5 collector and oem 2.5 itr gasket straight pipe to a dyno max muffer bolts up perfect on 92-95 civic h/b with alot of ground clearance $350 for both selling together quiet set up cmes with new o2 sensor
New napa b series axels $120 both
95 gsr distrubutor with ngk blue wires 1,600 miles on the just put new cap and rotor $150
I have all motor mounts rear hasport mount stocl side munts and tourque mounts with t bracket $180 for all.
LS-V golden eagle kit like new$170 with tap n tool included looks brand new...
95 gsr engine harnss $120 un cut
AEM itr 3 inch 2 piece in take with k&n filter $180
Old Apr 28, 2011 | 03:29 AM
jdmjunkieXL's Avatar
Default Re: Alaniz Comp Gsr Head Built B20z Block B16 Trans etc
willing to part out block?
Old Apr 28, 2011 | 09:07 AM
viper_linx's Avatar
pics of the head ports?
Old Apr 28, 2011 | 10:44 AM
negroeg6's Avatar
I really don't want to part outthe block,,,, u have an email or number I can send pics too I have pics on my phone from when I picke up the head from Joe himself
Old Apr 28, 2011 | 10:46 AM
CRXB16B's Avatar
bump
Old Apr 28, 2011 | 10:51 AM
viper_linx's Avatar
do u have any up to date pics ?
Old Apr 28, 2011 | 11:54 AM
ef1.8's Avatar
Are you going to sell the black shell this came out of?
Old Apr 28, 2011 | 12:36 PM
civic2slo's Avatar
What did the setup run in your hatch?
Old Apr 28, 2011 | 02:15 PM
Black-Ty [EG6]'s Avatar
glws
Old Apr 28, 2011 | 02:41 PM
negroeg6's Avatar
If the price is right I would....
Old Apr 28, 2011 | 02:43 PM
negroeg6's Avatar
I'm taking the head to the machine shop tomorrow should have some up soon
Old Apr 28, 2011 | 03:27 PM
civic2slo's Avatar
1/4 e.t.?
Old Apr 28, 2011 | 03:39 PM
negroeg6's Avatar
13.5 2.4-2.5 60ft no traction on 22x8 m/t slicks
Old Apr 28, 2011 | 10:22 PM
civic2slo's Avatar
what was your trap speed?
Old Apr 29, 2011 | 04:02 PM
negroeg6's Avatar
Old Apr 29, 2011 | 04:12 PM
viper_linx's Avatar
whats that black stuff in the port? head had a crack that was fixed?
Old Apr 29, 2011 | 04:25 PM
negroeg6's Avatar
I posted pics from when I picked up the head late last year so u could see the ports. He used some sort of grease or lube on his heads to keep them lubricated so if they sit for a while.
Old Apr 29, 2011 | 04:31 PM
viper_linx's Avatar
post some recent pics of the ports.. and how it looks today..
Old Apr 29, 2011 | 04:57 PM
negroeg6's Avatar
Its at the machine shop i will pick it up monday or tuesday and ill post pics then.....
Old Apr 29, 2011 | 04:58 PM
viper_linx's Avatar
kool... bump
Old May 1, 2011 | 12:33 PM
oneiro's Avatar
I can vouch for this head, SETUP is CLEAN
Old May 2, 2011 | 09:43 AM
eg6style's Avatar
Bump for a clean setup. Wish I had the cash for the hondata
Old May 8, 2011 | 11:22 AM
negroeg6's Avatar
Old May 18, 2011 | 11:25 AM
sh!ft's Avatar
Who the fack changed my title?!
still got s300?
Old May 18, 2011 | 03:49 PM
negroeg6's Avatar
sold
gogetta
Oct 5, 2011 03:10 PM
gsrwanted
Nov 15, 2008 07:18 PM
Your Name
Nov 4, 2008 10:35 AM
wade
Dec 20, 2006 05:36 PM
morgan@synapse motorsport
Apr 16, 2006 02:25 PM
