84.5mm gsr all motor
Old Apr 27, 2011 | 07:04 PM
la001268's Avatar
Default 84.5mm gsr all motor
Hey Honda-tech. I am in the middle of building an all motor gsr just got the block back from being sleeved. Have eagle rods (ls) using a 89mm crank balance and polish. Still debating comp was going with 13:1 but still not sure. This is not my daily but want to drive to and from track. Will tune on s300 and gas will be e85. Head consist on crower spring and retainers with flat valves.'will be using pro 3'cam skunk 2'manifold and 68mm tb. Hytech rep headers reg size'800cc injectors.
Please give me feed back if I need to change any thing.
Old Apr 27, 2011 | 07:19 PM
1998GsRIntegra's Avatar
Default Re: 84.5mm gsr all motor
Better header. Have one custom made...SMSP or the like.
Old Apr 27, 2011 | 07:58 PM
UncleD's Avatar
...and another one.
Old Apr 28, 2011 | 05:07 AM
Smokalicious's Avatar
I'd get a better Header at least a Big Tube and bigger Manifold Victor X, BBK, something along those lines
Old Apr 28, 2011 | 07:49 AM
la001268's Avatar
Thanks, for those with feed back and for the ones that want to write dump comments jump off. Trying to build a motor here.
Old Apr 28, 2011 | 09:38 AM
BADGUYNY's Avatar
definitely get a bigger manifold with a bigger motor your going to need it. I would go with 14.1 compression a friend of mine has a similar build and that motor is a beast. The hytech reps made pretty good power on his car, two of our other cars run different a header one runs a Bisi and made nice power and the other a RMF and it also makes good power. Two of these cars make 250+ and run low 11's. Dont forget a nice port job..Luke from 4piston has done some heads for us and they are sick
Old Apr 28, 2011 | 11:32 AM
slowsleeper's Avatar
Run more compression if you are going to be running E-85 so take advantage of that octane. I am at about 14:1 on E-85 myself.
Old Apr 28, 2011 | 11:55 AM
jerrys7583's Avatar
X2 bigger manifold, good port job. I too making around 250hp on RMF, Victor X and smaller cams.
Old Apr 28, 2011 | 01:24 PM
C_Rock77's Avatar
Putting that kind of work in, you need a GOOD header.
I can't speak on the CR, etc on E85, I don't have the knowledge to speak on it.
As for headporting, Brad @ RLZ is one of the best honda headporters in the business. Think about the flat faced valves. Realize that the added weight of the flat-faced valves will be detrimental, especially when you're revving high.
Old Apr 28, 2011 | 01:43 PM
96dxB16's Avatar
Agreed, get that compression as high as possible. E85 is rated at 105 octane but tunes more like ~112 because it burns much cooler than regular petroleum. 800cc injectors should be plenty, get a fuel pump also if you don't have one yet.
Old Apr 28, 2011 | 07:57 PM
la001268's Avatar
Thanks for all the feed backs and yes I have a walbro fuel pump
Old May 3, 2011 | 07:10 AM
mhax's Avatar
sound like a nice setup!
Old May 3, 2011 | 07:29 AM
OH_1fstgsr's Avatar
Header with 3" collector, 3" exhaust
Victor X manifold
Get ID1000 injectors, much better spray pattern over the RC800's.
insomniac791
116
Feb 28, 2010 10:18 PM
mikkey1
Feb 17, 2007 02:22 AM
ep3boy
Jul 25, 2005 09:36 PM
92LSVTEC
May 1, 2005 08:10 PM
Turbo R
22
Dec 4, 2004 12:02 PM
