Odds and ends to accomplish before swap(Q's about fluids, belts, and misc.)
I am about to swap in a 99-00 b16a2 into my 97 dx hb. Got some questions to wrap things up.
In the manual it says to replace a ton of washers. Do I need to order these from Honda as well? OR do I just go buy appropriate metric washers?
I guess I am going to be draining pretty much all the fluids before the swap? Any suggestions on what to replace them with (obviously the corresponding fluid )? I guess the question is do I need aftermarket stuff, or if need is the incorrect term whether I will see any benefit from using upgraded tranny oil or similar.
Also as long as the linkage is out of the car I would like to get a short shifter. Any suggestions on brands?
to avoid ANY problems - use Honda
stuff only,
eg Honda "crush washers"
Honda MTF, Honda coolant, Honda filters.
but if you think you can get better than Honda, go for it. (i dont think i can, but i am in Australia - the US might have some better aftermarket stuff...)
but anyways,
good luck! i hope you dont need too much
t..
stuff only,eg Honda "crush washers"
but anyways,
t..
alexdog69
Oct 20, 2005 03:34 PM
