Where to mount oil pressure sending unit
Old Apr 27, 2011 | 04:15 PM
josephcmiller2's Avatar
Default Where to mount oil pressure sending unit
I have an Autometer oil pressure gauge setup with the sending unit that goes under the hood and an electric gauge for inside the car. I have some braided hose to go from the block to the sending unit. Should I mount the sending unit somewhere on the block or should I mount it on the firewall? The hose is flexible, but this motor sees a lot of vibration. The last time I hooked this up I used copper tubing and mounted the sending unit on the block. The copper tubing vibrated until it broke, losing all my oil. I will be connecting this to where the stock oil pressure switch is currently.
Old Apr 28, 2011 | 04:32 AM
kyden's Avatar
Default Re: Where to mount oil pressure sending unit
mount it on the firewall. the vibrations will kill the sending unit.
Old Apr 28, 2011 | 08:21 AM
Thanks, I definitely don't want that. It will be a lot easier to mount that way. You don't thinly the vibrations will wear the oil line, do you?
Old Apr 29, 2011 | 06:19 AM
Cynical 1's Avatar
i always use a sandwich adapter for the oil pressure sender, and whatever else i need oil related - it mounts between the oil filter and the oil flange or cooler on the block.
most have 2-3 holes for various items to be attached (holes can be blocked off if not needed) and can be had cheap on ebay - BWR or other knock-offs.
i've tried the tubing/remote location route, and have never liked the way it worked or looked, or the longevity... mych happier with the sandwich adapters.
Old Apr 29, 2011 | 06:40 AM
turtleman321's Avatar
same. never had a problem with cylinder type sending units with the 1/8 npt threads on one end. if you use the copper tubing you should put a set of curls in it like a spring to absorb vibrations.
lude98SH
Sep 22, 2008 02:49 PM
Maxcapacity
May 22, 2008 06:04 PM
88crxhfb16
Jul 23, 2005 11:02 AM
2khb
Mar 10, 2005 06:52 PM
Random.Hero
May 31, 2002 08:48 PM
