whats the easiest way to tell if my fuel pump is working?
Old Apr 27, 2011 | 04:15 PM
400whp's Avatar
Icon2 whats the easiest way to tell if my fuel pump is working?
The car wont start and I cant hear the fuel pump. Should I be able to hear it? Whats another way i can check? The main relay is clicking.
Old Apr 28, 2011 | 04:07 AM
CWBETB's Avatar
Default Re: whats the easiest way to tell if my fuel pump is working?
Put the ignition on, you should hear the fuel pump priming, kinda sounds like a electric buzz/foom sound. Sticking your head on the rear seat you should really here it. If no sound, good chance your Main relay may be dead "main relay controls the Fuel pump" I would start with the relay under the dash they are known to go bad, its cheaper and much easier to fix. tearing apart a fuel pump is messy and more expensive.
Old Apr 28, 2011 | 05:45 AM
213374U's Avatar
0x5359-0055
Community Builder
The cheapest route, try to re-solder the connections in the Main Relay to fix it, there's a how-to around here somewhere and a little searching should find it easily. And grab a Hayne's manual and a multimeter if you don't already have one. Should give you resistance specs for checking the fuel pump itself.
Old Apr 28, 2011 | 07:21 AM
lazy14's Avatar
can you jump power straight to the fuel pump to see if it turns on?
Old Apr 28, 2011 | 07:35 AM
91GEDHATCH's Avatar
I can say from experience it's more likely to be a relay problem, pumps do go out but just check out the relay before you get in too deep.
P.S.- Anyone who knows where to find the relay repair writeup please message me!
Old Apr 28, 2011 | 08:09 AM
CWBETB's Avatar
http://www.honda-acura.net/forums/do...relay-fix.html
Fix applies to Civic's also, your are resoldering the solder points
Old Apr 28, 2011 | 02:20 PM
213374U's Avatar
0x5359-0055
Community Builder
What are the odds, gotta go fix the main relay on my 91 LS
slowEGles
May 13, 2013 06:16 PM
JimmyM86
15
Oct 18, 2007 08:44 PM
juanchoenuncrx
Aug 29, 2007 07:59 AM
solofthesouth
Apr 15, 2006 06:32 AM
si 1
Dec 21, 2005 11:03 AM
