'99 ex civic/water on floor boards,no where else??? help me plzzz
i got water on my passenger floor boards,i dont use the ac,yet cuz i just got car,i do use the defrost thou,heres the prob we had a hell of a down poor,and now my passenger floors front and rear are soaked,i checked everywhere for a leaks no signs,the seats, panels on the door all around there r dry literally just the floor boards what hell could it b,it has no smell to it like, just sitten water, ne and all help is greatly appreciated....
ok so how would water go up into the car from the bottom,and i also checked heater core and ac behind glove box nothin there either..............what should i do when i c the plugs if that is it...... thx
My '97 has a leak in the weather strip on the windshield.. and I also suspect the rear window as well. The leak in the front makes it was past the pillar and ultimately onto the floor. Really annoying..
Mine does too however when the previous owner had the windshield replaced, I don't believe it was done properly.. or the aftermarket strip is not sitting on the body properly. My solution was using plumber's putty to stop the leak.
word. my car is doing the same. I was wondering why my carpet was a little wet when I got in it the other day. I also heard this crazy noise all of a sudden definitely sounded like wind! I was baffled, I couldnt pin point what would make that noise and why my carpet was wet.
Turns out the PO didnt have the windshield installed properly.
I only found out because I went to clean the front windshield and it pushed out. DEF NOT SAFE. It doesnt look like they used any sealer on it. It looks like they set the glass and put the molding around it. WTF...anyways man I would check the windshield. lol
even in defog ur a/c still runs. i had the same thing with my 4runner. it turned out to be that the condensation drain for the a/c was clogged and over filled into the cab. i didnt notice it bc of the rubber mats untill i took them out to clean n the carpet soaking. but there will be a rubber hose under ur glove box going threw the fire wall, it wouldnt hurt to check it for any blockage
drfundy
15
Apr 1, 2020 02:59 PM
charlieway
Apr 30, 2004 03:23 PM
