1993 honda civic dx spark problems
Old Apr 27, 2011 | 01:03 PM
93civicdxsocal's Avatar
Icon2 1993 honda civic dx spark problems
not sure whats goin on here, i have a 1993 honda civic dx 4 door 1.5L. its got a new distributor no corrosion. checked for spark directly from coil, no signal to distributor. car worked yesterday, sat overnight and wont start now.. it turns over but wont start. its has fuel pressure and is getting fuel. but no spark. any help would be greatly appreciated.
Old Apr 27, 2011 | 01:37 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: 1993 honda civic dx spark problems
http://techauto.awardspace.com/ignition.html
Old Apr 27, 2011 | 01:43 PM
Ts not vtech.. Its a stock 1.5L motor. Manual transi
Old Apr 27, 2011 | 02:03 PM
Former User's Avatar
Aftermarket replacement distributor?
Is there battery voltage at the Blk/Yel wire attached to the coil and ignite unit?
CEL codes?
Old Apr 27, 2011 | 02:10 PM
what does the cel codes stand for? do i hook up and obd1 scanner to it?
Old Apr 27, 2011 | 02:11 PM
and the distributor is brand new. and yes there is battery voltage at the coil and ignite unite
Old Apr 27, 2011 | 02:27 PM
Click on the CEL sticky at the top.
Old Apr 27, 2011 | 02:30 PM
This^ does not rule out the distributor. ^Aftermarket?
You might want to resistance test the coil and test the Yel/Grn wire that runs from the ICM to the ECU for a short or open.
Old Apr 27, 2011 | 02:45 PM
the numbers on top of the distributor are dst17427 and below that it says bk10e4. its definitely not the original one that came with the car.
Old Apr 27, 2011 | 02:51 PM
how do i find the jumper plug to check the codes? the directions on that site dont help. i pulled the carpet back and found the ecu but dont see said jumper plug anywhere..
Old Apr 27, 2011 | 03:04 PM
ok i found the jumper plug. did the test. came back with 4 longs.. but there is no code 40.. im straight lost now.
Old Apr 27, 2011 | 03:15 PM
just reset the ecu and tryed to start and got nothing. tryed the jumper code again and it came up with a solid light on, no flashing whatsoever. any other options to figure out whats wrong before i go spend money on a new distributor.. would suck if that wasnt the problem.
Old Apr 27, 2011 | 04:35 PM
ok so its now working! my buddy brought over an old distributor and switched out the insides. and now my car starts.. altho the alternator belt is ate to **** and about to break.. so looks like ill be getting that belt and replacing it.. anyone know of how to do that, or a website with directions showing how to do it???
Old Apr 28, 2011 | 03:35 AM
Sonia's Driver's Avatar
It's hard get the tension right on the alternator belt because you have to hold the alternator back to tension the belt while you are tightening the alternator bolts.
You should probably purchase a manual that can give you directions with pictures.
Thecargoddess
Jul 3, 2024 07:09 PM
BUGGYCAR
Sep 20, 2017 07:35 AM
Ssauber21
Jan 14, 2013 10:05 PM
Tchay
Oct 14, 2012 12:17 AM
