climate control stays on after i turn the car off
So i have a 94 cx hatch with a b18b1 yesturday i came to
work and turned my car off when i got in the car after work
i noticed that the indicator lights on the climate control were on i turned the blower on and it worked with out the car being on but its not doing it tonight
that's interesting. first, i suggest using some punctuation that would facilitate in others being able to decypher what it is you're trying to tell us.
secondly, my guess as to what your problem might be is that you have a short in the main ignition harness, or your ignition switch is failing. You didn't really give anything else to go on so it's hard to say. Is everything powered up like it would be if the car were in the run position, or is just the climate control?
I have this same problem with my 95 Integra. (That's how I found this thread on Google.) I was thinking that something is shorting and backfeeding power to the climate controls. It kills a battery OVERNIGHT. Can't even recharge them after, totally ruined. The problem is also intermittent. I checked for amp draw at the alternator thinking maybe it was a diode, but it's clearly something related to that system, since nothing else stays powered on. I found on another thread that it could be something like the radiator control module, but mine isn't constant, right now it's not doing it, but any day it will. I'm not sure what it could be yet, I need a good wiring diagram to see where power could be coming from. If I figure it out, I'll repost about it.
CivicKiller123
Honda Civic (2001 - 2005)
Sep 12, 2013 11:24 AM
eL
Jan 24, 2006 04:03 PM
Kevedge
Aug 19, 2004 01:40 AM
