b20 in CRX ecu help
Old Apr 27, 2011 | 11:17 AM
91CRX-T's Avatar
Default b20 in CRX ecu help
im getting a b20b and I am going to be using all of the obd2 components (dizzy alternator and fuel injectors) with rywire conversion harnesses. my question is... can I run an obd1 ecu and if so what ecu would be best to use? im a noob to hondas and any help would be great! Thanks H-T for any help!
Old Apr 27, 2011 | 07:57 PM
91CRX-T's Avatar
Default Re: b20 in CRX ecu help
What would be my best option as far as which ecu to run?
Old Apr 27, 2011 | 08:05 PM
Deetz's Avatar
Crazy Honda Guy
From experience, you should run OBDI and look for a PR4 ecu. It seems to run better on the B20 than an obdI P75
Old Apr 28, 2011 | 06:28 AM
91CRX-T's Avatar
Should I use a PR4 with a b20 basemap or will just a stock PR4 do the trick. This is going to be my DD and only plan on adding I/H/E
Old Apr 28, 2011 | 06:45 AM
Turbo-LS's Avatar
You should get your self an obd1 ecu and have it tuned. any stock ecu is going to be detuned for a b20 engine. The bigger displacement needs more fuel than an LS ecu will provide not to mention its designed to run with 87 octane, timing and 90+ octane make a big difference in both the b18 and b20. If your going to be adding I/H/E you should definatly have it tuned to see the potential otherwise dont bother. And no you shouldnt drive it on a base map, its a base to start with not a tune to drive with
98bucket
Nov 6, 2010 09:59 AM
93redeghatch
Mar 24, 2010 11:43 AM
6footmidget
Dec 23, 2009 03:20 PM
TheBigSPool
Engine Management and Tuning
Oct 1, 2009 09:23 PM
str8drift
Jul 12, 2008 11:15 PM
