unused pins at ECU connector?
Old Apr 27, 2011 | 07:44 AM
CivicxTree754's Avatar
Photogenic
Loved
Default unused pins at ECU connector?
Im trying to easily hook up Vtec in my 93 Civic lx mini me. Im wondering if there are any 2 unused pins in the connector at the ecu that I can de-pin and move to the needed pin location for the vtec sensors. I read that I can run the vtec pressure sensor (whatever its called) to my oil pressure wire so that may be 1 less needed pin. Anyhelp? Im just not trying to take a trip to the junk yard to cut off the needed connector w/ pins.
Old Apr 27, 2011 | 09:57 AM
fryman's Avatar
Default Re: unused pins at ECU connector?
You should just go to the junk yard and get a ecu connector chopped off with a few inches of wire attached. Then just remove the pins you need and snap them in the ecu connector on your car. Then just solder wires of the proper length to those pins, so that the wire will reach the vtec plugs, and solder the wires to the wires in the vtec connectors on your solenoid. That's what I did and they shouldn't charge you much for those connectors....probably only a couple dollars.
Old Apr 27, 2011 | 11:51 AM
Photogenic
Loved
I know that option. I just dont have time with school and work and my local junk yard closes at 4pm. lol. Well if I dont get a definitive answer guess i'll have to make time.
gorthjr
May 11, 2010 08:55 PM
94eg'n
Sep 24, 2007 04:09 PM
EGB18C
Feb 2, 2006 02:57 PM
SuperNemeSis
Mar 29, 2003 02:32 PM
stangkilla
Dec 12, 2001 08:02 AM
