does anyone make an internally wastegated T4??
Old Sep 29, 2002 | 08:40 AM
Boostless97Lude
Guest
Posts: n/a
Default does anyone make an internally wastegated T4??
i just bought a GReddy turbo kit for my Prelude, engine is completely built, but i talked to some people that said the 18G might be good for about 20-22psi, but would lose efficiancy at around 7000-7500 rpms. who makes a really good, possibly even ball bearing, T4, T3/T4 or equivalent sized turbo with an INTERNAL wastegate, that will bolt up to the GReddy flange? is this a question i need to be asking DSM owners since the turbos are the same?
[Modified by Boosted97Lude, 12:41 PM 9/29/2002]
[Modified by Boosted97Lude, 1:10 PM 9/29/2002]
Old Sep 29, 2002 | 03:42 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: does anyone make an internally wastegated T4?? (Boosted97Lude)
bump....
Old Sep 29, 2002 | 03:47 PM
sutrusu's Avatar
i dont think you're going to find an internal wg t4.. and if you ever do, there's no way it's gona bolt up to that manifold!
Old Sep 29, 2002 | 07:06 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: does anyone make an internally wastegated T4?? (sutrusu)
i kinda figured that, but i figured i'd ask anyways
Old Sep 29, 2002 | 07:38 PM
BlueSi2k's Avatar
how about a 20g turbo? pretty sure it will bolt up but not sure about the wastegate...
Old Sep 29, 2002 | 07:50 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: does anyone make an internally wastegated T4?? (BlueSi2k)
a 20G will bolt up, they are internally wastegated, but you can't actually get a "20G" in a ball bearing, not that i have found yet anyways
Old Sep 29, 2002 | 08:57 PM
HybridKOOP's Avatar
Correct me if I'm wrong.. but MKIV Supras run T4's, stock... internal gates.
Old Sep 29, 2002 | 10:54 PM
DLB1994's Avatar
Default Re: does anyone make an internally wastegated T4?? (HybridKOOP)
just get a TDH05 20g you dont need ball bearing it only helps spool 200-500rpms sooner
Pfieff
Oct 28, 2006 07:13 AM
Tippyman
May 13, 2006 07:09 PM
civictypenos
May 11, 2003 03:59 AM
PreIudeSI
Jul 22, 2002 06:35 PM
