***NEED HELP*** AP2 CLUSTER MODIFRY ECT
Old Apr 26, 2011 | 07:16 PM
B20PWRD's Avatar
Default ***NEED HELP*** AP2 CLUSTER MODIFRY ECT
Im having trouble installing my Modifry ect unit in my Civic EM1 for my AP2 cluster. I know where the instructions are but unfortunately it only gives instructions for s2000 drivers and not for civics.
im trying to figure out what color the wire is for the 5v power supply coming from my civic's ecm. in the s2000, its yellow/blue, but i dont see that wire coming from the civic's ecm end. so what color is the 5v power supply from the ecm in the civic?
And what color is the ect wire(temp sensor) coming from the civic ecm? in the s2000 its red/white, but again i dont see that wire in the civic, so im guessing its a different color. which wire is it?
PLEASE HELP!!!
Old Apr 26, 2011 | 09:34 PM
jdmb20eg6's Avatar
Default Re: ***NEED HELP*** AP2 CLUSTER MODIFRY ECT
For the 5V i connected it to my sensor voltage for TPS which was yellow/white. In your case it would be VCC2 pin 28 (yellow/blue) on connector "C". The temp sensor color is the same as the s2000, red/white, pin 26 on connector "C" also. Here's a link to the ecu pin out for the EM1. Hope that helps.
http://www.ff-squad.com/technet/wiring.obd2b.htm
Old Apr 26, 2011 | 10:28 PM
B20PWRD's Avatar
connector c?? i only have connector A and B. i have an AP2 cluster.
Old Apr 27, 2011 | 07:20 AM
jdmb20eg6's Avatar
connector "C" on the ecm. Click on the link i gave you.
xlaox
Honda S2000
Dec 11, 2006 05:26 PM
DB1_559
Jul 27, 2006 01:44 PM
Boofster
Honda S2000
23
Apr 28, 2006 01:24 PM
tegon-gsr
Mar 19, 2004 08:41 PM
