G2 integra -> G3 integra parts swap
Old Sep 29, 2002 | 07:46 AM
zilverz's Avatar
Default G2 integra -> G3 integra parts swap
Gonna possibly convert an automatic G3 to Manual ... i have a 1992 G2 5 speed .... the pedals.. pedal assembly ... and shift linkage ect .. should all line up right ? the 92 ECU work fine as well in the 1995 G3?
Old Sep 29, 2002 | 06:47 PM
Brian_92GSR's Avatar
New User
Default Re: G2 integra -> G3 integra parts swap (zilverz)
Use the ECU that goes with the engine you're using. The shift linkage and change rod shouldn't be a problem, at the most you'll have to drill some holes to mount it to the car. I'm really not sure about the pedal assembly. If it doesn't bolt up you'll have a problem, because the pedal assembly for the G3 is for a hydro tranny, and you need to attach a clutch cable to the pedal.
Old Sep 30, 2002 | 07:17 AM
zilverz's Avatar
Default Re: G2 integra -> G3 integra parts swap (Brian_92GSR)
Hmmm ive been told that the 92->95 civic pedals/assembly would bolt right in to the 95 integra .... hmmm think this 92 integra is all that different ?
Anyone else know of anyone robbing manual conversion parts from a G2 integra ?
Old Sep 30, 2002 | 08:44 PM
zilverz's Avatar
ttt
HondaMechanic24
Dec 14, 2012 12:42 PM
corbocivicferio
Jul 15, 2010 02:26 PM
bap168
Sep 16, 2007 06:33 AM
AzntstyleZ
Dec 22, 2003 12:26 AM
