HELP EM1 cruise control problems
Old Apr 26, 2011 | 03:07 PM
iboughtas2k's Avatar
Icon2 HELP EM1 cruise control problems
hello guys! i need a help with fixing my cruise control system,
i bought a EM1 without cruise control, and soon after i found out that the previous owner completely deleted the SRS as well
so i bought a complete cruise control system and re-installed
there are brake sensor and crutch sensor installed.... the cruise button light comes on when pressed but whenever i try to engage the cruise control system to work by pressing the switch on the steering.. it wouldnt work
im a newbie with EM1... i did a search and sometimes you have to disable the cruise control system too when disabling the SRS system, because the electrical wires for SRS associate with cruise control system
i have all the parts installed correctly and the fuse is fine... i would like to know what could have been done possibly by previous owner and what it takes to restore the cruise control system.. i dont care too much about the SRS but i do desperately need cruise control to work
thank you in advance
Old Apr 26, 2011 | 03:56 PM
Default Re: HELP EM1 cruise control problems
bump! any infos would be appreciated
Old Apr 26, 2011 | 05:21 PM
Former User's Avatar
Are the rubber/plastic stoppers that press on the cruise switches on the brake and clutch pedal missing?
Does the horn work?
Old Apr 26, 2011 | 07:15 PM
Does the horn work?
thank you for your input!
i dont know what rubber stoppers you are talking about
but as far as my observation about the switch and connectors on the brake and clutch pedals are all connected and seems like they are in right place
my horn did not work, so i thought it was cable reel, so i replaced the cable reel
now the horn works but still no cruise control...
do you think the vacume line connects to the chasis matters? i have one of the two vacume lines from the actuator connected to the intake manifold but the other one which supposed to be connected the chasis is not there but i didnt think it would matter
Old Apr 26, 2011 | 08:00 PM
The two switches on the clutch pedal are shown below. The rubber stoppers that press on the two switches are colored blue and red. Check whether the red stopper is missing or damaged on the clutch and brake pedals.
Old Apr 26, 2011 | 08:50 PM
^ thank you for the diagram for easier understanding
i just checked those two switches and they seem to be fine...
i keep thinking it is electrical related issues....
Old Apr 26, 2011 | 08:55 PM
Is the cruise control stopper in place on the clutch pedal?
Old Apr 26, 2011 | 09:25 PM
^ thanks for the diagram...
so the red switch is supposed to be pushed when clutch pedal is in rest?
is that how the cruise control become enabled?
cuz my red switch is not having any contact either in rest or engaged
i think this is why CC is not engaging cuz the CC switch is not being pressed right?
i have a feeling i just discovered the problem if so THANK YOU SO MUCH!
can i adjust the clutch pedal so that the switch would be pressed when in rest? or do i have to get a whole new switch?
Old Apr 26, 2011 | 09:32 PM
Yes, the cruise control switch must press on the red stopper with the clutch pedal up. You can fix this by screwing the switch closer to the stopper and by adjusting the pedal height by screwing in the push rod.
Old Apr 26, 2011 | 09:38 PM
thank you so much for your help i really appreciate it...
im gonna go adjust the switch position and test drive it
hopefully it works
Old Apr 26, 2011 | 10:06 PM
i just came back from the test drive after adjusting the switch position... and guess what? it WORKS!
although the cruise control light on dash does not come on... it works... this is good enough for me..
i go on a 200 mile trip a lot and for this reason,, i have been driving my S2k a lot and put miles on the S when i could just drive the civic...
thank you very much for your help Ron!~
Old Apr 27, 2011 | 05:25 AM
Nice. Replacing the cluster cruise light bulb will be pretty easy.
JHFP
Oct 17, 2018 01:35 PM
KDoGx504
Dec 17, 2005 08:52 PM
HuskerHybrid
Jan 16, 2003 04:58 PM
samdawgsol
Feb 19, 2002 02:13 PM
