B16a2/S4C transmission - starter fitment problem
Old Apr 26, 2011 | 01:18 PM
highmfer's Avatar
Default B16a2/S4C transmission - starter fitment problem
So I have now gone through 4 different starters (rebuilding them myself and one brand new one) and I cannot get the flange bolts to match the trans. I have a B16A2 motor and order the parts accordingly. WTF am I doing wrong!? Pls help im startint to loose sleep over this!
Old Apr 26, 2011 | 01:24 PM
Former User's Avatar
Default Re: WTF starter
The starter bolts to the transmission not the engine. What transmission do you have?
Old Apr 26, 2011 | 01:32 PM
blackedEk's Avatar
Old Apr 26, 2011 | 05:55 PM
highmfer's Avatar
S4C trans, which is what was sold with the motor factory...correct? It is a USDM motor.
Old Apr 26, 2011 | 08:21 PM
Which bolts are you having problems with?
Old Apr 27, 2011 | 07:00 AM
highmfer's Avatar
Both...I can get one to line up but not the other. The flange will fit the opening in the trans but then the bolts don't match the holes and vise versa if one bolt is started b4 the starter is fit into the opening. Is it possible to have a difference between and US Si and a Canadian Sir?
Old Apr 27, 2011 | 08:49 AM
Default Re: B16a2/S4C transmission - starter fitment problem
I edited the title to one that better describes the problem and that hopefully will help you get an answer.
Old Apr 27, 2011 | 09:11 AM
highmfer's Avatar
cheers...thanks
Old Apr 27, 2011 | 09:15 AM
highmfer's Avatar
Old Apr 27, 2011 | 09:55 AM
hyperblu's Avatar
look at the old one
Old Apr 27, 2011 | 10:02 AM
94EG8's Avatar
Seagull Management
No, both are the same, you might want to order for an Integra though ('94 - '01 with manual transmission) I'd say it's pretty likely your local parts store has a screwed up listing for the civic.
Old Apr 27, 2011 | 12:30 PM
highmfer's Avatar
^^^you sir, are a genius!
Old Apr 27, 2011 | 12:42 PM
94EG8's Avatar
Seagull Management
Glad that worked out for you, parts store was mostly giving you D-series starters.
Old Apr 27, 2011 | 12:46 PM
hondaluver19's Avatar
I agree. Had this happen to me too.
Doomtorn
Feb 20, 2016 01:53 PM
slowLSTek
Transmission & Drivetrain
Apr 13, 2011 10:44 AM
fibereater
Apr 27, 2010 08:57 PM
