how big clerance on block/rod? Notch D16y8
Old Apr 26, 2011 | 10:55 AM
khmoe's Avatar
Default how big clerance on block/rod? Notch D16y8
I have a d16y8 that i'm upgrading with srp pistons and eagle rods.
Everything looked ok until i mounted the girdle and found out that i had to notch the girdle 1/8". then i started to search for notching d16y8.
But do i need to notch the block? it has a clerance, but how much should it clear?
i only checked with a ziptie that is about 1-1,5mm thikk, but the rod got stuck. How big of a clerance do i need?
sorry for my bad english.
Old Apr 26, 2011 | 12:07 PM
blackeg's Avatar
Default Re: how big clerance on block/rod? Notch D16y8
i had to notch my block under the cylinders. it was about 1/8 inch, but i had to take way more than that out of my girdle
Old Apr 26, 2011 | 12:15 PM
2kdrift's Avatar
read this
http://www.theoldone.com/articles/d_...building_tips/
Old Apr 27, 2011 | 08:54 AM
khmoe's Avatar
theoldone is for older blocks. my rods cleared, but had only 0,02-0,04" clearance.
I have started to notch the block now. i think i have like 0,07-0,09" is that good?
The Girdle has to be notch alot i think. have'nt messured
Old Apr 27, 2011 | 10:17 AM
Hybrid96EK's Avatar
It's not for "older blocks". It's for the d series in general. I had to do it to my 99 y8. Can't get a whole lot "newer" for the y series. The girdle requires a good deal of notching depending on the arp rod bolts you have. The block, I had to remove a good 1/4" below the cylinder/sleeve.
jdmf23accord
Jan 12, 2013 07:30 AM
mrbigg9032
Jul 9, 2007 07:43 AM
civichb95lnd
Dec 11, 2005 05:49 PM
