What other model shifter cables will work on an EP3? (please help)
Old Apr 26, 2011 | 08:23 AM
JDMBoost2's Avatar
Default What other model shifter cables will work on an EP3? (please help)
Hello,
I have come here because the left side shift cable linkage (1s, 3rd, 5th gear) on my 02 EP3 has decided to call the quits and needs replacing. I contacted my local dealer and it costs and arm and a leg for a pair of OEM EP3 shifter cables, extremely overpriced. Before I have to buy brand new OEM cables I would like to know if any other model Honda shares the same cables with the EP3?
Any help would be greatly appreciated, thank you
- Steven
Old Apr 26, 2011 | 10:20 AM
WhiteOnRice's Avatar
Default Re: What other model shifter cables will work on an EP3? (please help)
I don't believe any other cables would work. I'd get a used set from a junkyard or someone parting out a totalled ep.
Old Apr 26, 2011 | 04:08 PM
mustclime's Avatar
yup....never seen them wear out before....have you checked to see if its hooked up right?....they kinda have to twist into place, one could have popped out of its holder under the dash.
Old Apr 27, 2011 | 08:09 AM
JDMBoost2's Avatar
Ya I thought it was odd as well, everything under the dash is all hooked up properly, nothing is visibly broken. On the shifting mechanism in the engine bay, again nothing is broken. The problem is when the car is put into a gear, it won't shift back out into neutral. Only 2nd, 4th and Reverse can be shifted into and 1st, 3rd, and 5th cannot. So then we took it all apart and noticed that the left side shifter cable won't push the mechanism back into neutral or into 1st 3rd or 5th.
It's all still connected but the only thing I thought it could be was the cable under the shielding is compromised.
Old Apr 27, 2011 | 09:37 AM
turboteg2nv's Avatar
Is it hitting your cold air intake?
Old Apr 27, 2011 | 10:06 AM
JDMBoost2's Avatar
No there is a good distance between it and the intake, why do you ask?
Old Apr 28, 2011 | 05:08 AM
mustclime's Avatar
pull the center consol, thats pretty the only way you can check the lock in place for the shift cables.
rudebwoy
Sep 26, 2014 04:16 AM
gizmo818
Aug 20, 2012 07:31 PM
FGtwo
Mar 9, 2011 06:16 PM
SacrificeTheory
Honda Civic (2006 - 2015)
11
Jan 7, 2008 07:09 AM
type-GGSR
Dec 5, 2007 07:42 AM
