do i need a knock sensor for my lsv
hello everyone. i just wanted to know if i need a knock sensor for my car i have a 92 teg and im dropping in a lsv(pr3 head and a b18b block). i took the motor out of a 90 teg and it didnt have a knock sensor hooked up. so do i need one or car i run my car with out one. my ecu is a p28 with a b16 base map and im using ls auto harness. any help would be great
i dont have a tuning software i bought a p28 with a b16 base map already . but i have a chip from my obd0 ecu . could i use that chip i know that one is not programed for a knock sensor.
You can't use a chip from an obd0 ecu in an obd1 ecu, so don't even try it.
Your best bet would be to have the car dyno tuned or to order a basemap for the lsv setup.
You may order a 28 pin eprom chip basemap from our website
http://www.phearable.net/shoppingcar...emap-p-60.html
& drop it into the ecu your self.
There is an instructional video on our website on how to change your eprom chip in an already socketed ecu.
http://www.phearable.net/tech
Good luck!
b16civicrida
Mar 2, 2006 02:36 PM
