Transmission & Drivetrain Gearboxes, Differentials, Clutches
gear changer
Old Apr 25, 2011 | 11:45 PM
s4yama's Avatar
Default gear changer
Has anyone replaced the gear changer in a gsr or any other trans and if so what were the results? I have a gsr trans with carbon synchros, new third gear and sleeve. It wont go into gear above 8,000 and this is in my drag car. Any suggestions would be greatly appreciated.
Old Apr 28, 2011 | 06:42 AM
MR.johnson's Avatar
Default Re: gear changer
what "gear changer" are you talking about? shifter, slider, fork, or?
Old Apr 28, 2011 | 11:40 AM
Mista Bone's Avatar
D Tranny Guru
gear change assembly, there is a beefed up unit but I suspect it is your clutch that is giving you the issues.
Old Apr 28, 2011 | 02:04 PM
David @ Synchrotech's Avatar
I doubt that the problem is from the shift change assembly. We have used the heavy duty shift change assembly from Speed Factory on some of our builds. It works well for a Dog box or hi performance trans that tends to bend or break these parts. Here is a link for more info:
https://honda-tech.com/forums/performance-45/speedfactory-modified-shift-change-holder-assembly-b-series-2834286/
dr.vroom
11
Apr 30, 2014 11:31 AM
PsychoSiRex
Honda Civic (2006 - 2015)
Sep 16, 2009 09:15 PM
tomato_man
Apr 15, 2007 06:27 PM
b20civic
Sep 8, 2002 11:33 PM
