Honda Civic 1995 DX - code 41
Just replace head gasket started up engine got check engine light diconnected battier light went out took car for test drive car act like it was running out of gas change fuel filter and ox sensor car ran great can't get rid of code 41 what is a heated ox sensor
When creating a new thread in this forum, you must select an informative topic-specific title -- for example, not ''i need help'' or ''help me please'' -- so that members browsing thread topics can easily understand your tech problem or question without reading the first post. A good title also helps speed up and increase the number of useful responses by letting members know what precise information is needed.
When creating a new thread, specify in the title exactly what you need help with. ''I need help'' & ''need help asap'' will not suffice. As a matter of fact, it may delay responses or get your thread overlooked or even worse closed. Therefore, your title must clearly state the tech problem or question you have. A few examples of informative thread titles are:
''92 Civic Si: No fuel pump prime or spark after engine swap"
"Stock 99 Civic DX - engine won't crank but starts and runs with a push start"
"93 Del Sol has high and fluctuating idle after replacing throttle body"
Hondito94
10
Mar 23, 2013 06:49 PM
