EM1 stock strut bar fitment issue on EM1
Old Apr 25, 2011 | 06:55 PM
JManny's Avatar
Default EM1 stock strut bar fitment issue on EM1
I bought my Si about 2 weeks ago and didnt have the strut bar so I found a CTR bar on craigslist and test fit it but the bar was too long, I was only able to put it through the studs on one side and not the other. So I didnt buy it thinking it was the bar being effed up and got one from the dealer today and same problem. What could it be? A theory I have is that its slammed all the way that the strut towers flexed inwards a bit?? Just guessing.. I has Tein control master flex coilovers.
Old Apr 25, 2011 | 08:47 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: EM1 stock strut bar fitment issue on EM1
An Acura CL? Not even close to the same car, that is why it does not fit
As for a clean look, your best bet it to just buy a used ITR bar cheap, it will bolt right up, i did it on my 2000 em1, think i paid $60
Old Apr 25, 2011 | 08:59 PM
JManny's Avatar
By CL I mean Craigslist lol my bad
Old Apr 25, 2011 | 11:00 PM
98civdx's Avatar
Master Detailer
Has the car been wrecked?
I very very very highly doubt you could do any damage like that by being slammed.
My first thought is you have frame damage.
Old Apr 26, 2011 | 07:31 AM
98ekb16's Avatar
+1 sounds like the front end of that car took a good hit at some point.
Old Apr 26, 2011 | 07:36 AM
grumblemarc's Avatar
The Grumpiest
Probably the reason there isn't a bar on it in the first place.
Old Apr 26, 2011 | 07:48 AM
double0Si-'s Avatar
I had trouble getting my 2000 Si's stock bar back in after replacing the engine. Jack the car up from different points til it flexes enough to start it on there. You might get a loud bang when you lower it and it settles into its right spot. Re-tighten it down too.
Old Apr 26, 2011 | 09:27 AM
JManny's Avatar
Never been in a wreck I made sure of that when I bought the car. I'll try that today when I jack up the car to raise the suspension.
Old Apr 26, 2011 | 09:32 AM
NACvicSi's Avatar
How can you be so sure? If you are just going by carfax/autocheck then that's a negative. There are so many people that have accidents that don't get reported it's not even funny.
Old Apr 26, 2011 | 09:42 AM
The Grumpiest
Um. You sure you got the right bar? Pics of the almost fit?
Old Apr 26, 2011 | 10:16 AM
JManny's Avatar
I did do a carfax and nothing came up. Im **** when it comes to buy a car and from what I checked throughout the whole car I didnt notice any replaced body parts, bolts, or respray anywhere and if there was then they did a really good job at it.
I did get the right bar. I'll get some pictures up today.
Old Apr 26, 2011 | 10:22 AM
The Grumpiest
Carfax doesn't tell you squat if it's not reported.
Old Apr 26, 2011 | 10:36 AM
JManny's Avatar
I know that but doesnt hurt to look
Old Apr 26, 2011 | 10:43 AM
em1si5853's Avatar
Hey man the best thing u can do is look up the specs on the engine bay and measure all the points to make sure they all line up correctly. If they don't all match to factory spec then that car has been in a reck. Try searching for frame spec's, or call Honda and ask if they can look it up for u.
Old Apr 26, 2011 | 10:57 AM
JManny's Avatar
I will do that thanks
Old Apr 26, 2011 | 12:14 PM
98civdx's Avatar
Master Detailer
Carfax doesn't tell you ****.
My car has been wrecked, and noithing will pop up on carfax. If it is not reported it will not pop up.
You saying to doesn't look to hurt, what does that mean??
There is no reason a CTR strut bar shouldn't fit. If they fit normall ex/dx's which they do, and the SI bar fits those as well. the CTR will work.
Old Apr 26, 2011 | 12:38 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Wait. Which studs are you putting the bar into?
Old Apr 26, 2011 | 12:40 PM
B serious's Avatar
Or....look for VIN tags on the body? Might be 100,000X easier. If the frame was out of wack, I hope you'd be able to see some damage. If it once damage and then was repaired seamlessly...it's probably NOT out of spec.
Old Apr 26, 2011 | 12:52 PM
SeanK325's Avatar
post pictures...
Old Apr 26, 2011 | 01:15 PM
05foresterxt's Avatar
I had the same issue on my 99 Si. I never had the bar and finally bought it. I think I had the car on jacks or something but when I went to put it on, it didn't fit. I was like WTF? I even tried to bend it a little but still it didn't work. I drove the car for a day and tried it again, the bar dropped right in. I'm guessing something on your suspension has not settle right. Try jacking the car up and installing it.
Old Apr 26, 2011 | 01:37 PM
EJ8_Man's Avatar
I have a CTR bar on my EJ8 Coupe. Same chassis as an EM1. It fits perfectly.
Old Apr 26, 2011 | 02:21 PM
JManny's Avatar
The studs where the stock strut bar go on a EM1
All the VIN tags are there so no panels were replaced and no damage can be seen
Originally Posted by SeanK325
post pictures...
I will
Thats exactly what Im going to do
Old Apr 26, 2011 | 04:49 PM
JManny's Avatar
Here are some pictures. You can see on the second one how very little more it needs for the studs to go in.
Old Apr 26, 2011 | 04:56 PM
The Grumpiest
Is the bar bent? It's sooo close.
Old Apr 26, 2011 | 05:03 PM
JManny's Avatar
Nope I just got it brand new from the dealer. The first one I tried was the same but that one was a CTR used.
