95 civic d16z6 cranks then dies, ecu code 0
Yes I searched.
Already checked and cleaned all grounds, all fuses and relays are good. Swapped in another p28 (that isn't chipped) just to see if the cel would do anything different and it was the same.
Key in "on" position the cel comes on and stays on. Doesn't change when I jump the harness to check codes. Been driving it without an issue since last summer. Came home last night, shut it off, and went out this morning to fire it up. It cranked right up, idled up for a split second like normal then died. I haven't touched anything under the hood or driven it any differently. So damn random
Any ideas? thanks
Any ideas? thanks
Are you saying that you have been driving the car with code 0 for some time now?
Currently:
-Does the fuel pump prime?
-Is there bright white spark at the plugs?
Currently:
nope, I have been driving it without issue for a long time and just meant that I haven't done anything to it but change oil. I came home and shut it off like normal. Next day go out to crank it up and it does this.
Fuel pump primes loud and clear, hell it smells like it's flooding now. I'm double checking spark now, yesterday it was pretty good spark during the daylight. I'll check again.
At first spark seemed perfect because as soon as I would turn it over it would ignite, great white spark! But later I tried again and kept it turning over and noticed after the initial spark, that was it. It would stop after that. Which now makes sense as to why it will fire right up then die LOL.
ugghhhhh. My tach never jumped around but I guess it may still be an ignitor issue.
1) Turn the key off and unplug ECU connectors A and B.
2) Turn the key to ON(II).
3) Measure voltage to body ground at ECU connector terminals A25 and B1.
4) Test for continuity to body ground at ECU connector terminals A26 and B2 (turn key to OFF for this test).
5) If you use a jumper wire to ground ECU connector terminals A7 or A8, does the fuel pump run? (Turn the key to ON(II) again for this test).
http://www.phearable.net/tech/wiring...schematics.gif
Battery voltage = 12.01 with fan on
rechecked a25/ b1 again and both give me 12 volts. I must have not had a good connection first time
Grounded A8 and didn't hear the fuel pump prime, but it did spark a little
I forgot to mention this is originally a cx vehicle and harness. Vtec had to be wired in... but don't see how that would make any difference. Just throwing it out there.
I'm sure it's normally 12.5 instead of 12.4 but the past 3 days of cranking and not running is probably taking it's toll. I'll trickle charge it tonight.
Gonna test a8 with fan disabled now. brb
