What clutch do I need to buy?
I am going to be buying an aftermarket clutch for my vehicle soon, most likely an act. I have a d16z6 w/ a crx si transmission. Do I need to buy the clutch for the transmission, the engine, or am I going to have to buy seperate peices from both. A couple members on this board said that act makes a great clutch, does anyone have any other suggestions/comments? Thanks
You need to buy the clutch for the flywheel that you are using. The D16a6(SI) and the D16z6 use different size clutches. If the tranny is a 89-91 it will work with any of these clutches.
1988 21 spline 190mm
1989 20 spline 200mm
1990+ 20 spline 210mm
I hope this helps.
If you are using the Z6 flywheel, use the Z6 clutch disk and pressure plate, but get a throwout bearing for your Si tranny. When I had my D16Y8 going, I used a 96 clutch disk and pressure plate with my Y8 flywheel.
yes the 90-91 are 212mm
if you have a 88 tranny buy a 90-91 si pressure plate and flywheel along witha 86-89 accord disc, this will bump up your clutch size from 190mm to 212mm, big difference thats what i did and i like it...
