Whats the difference between PR3 & PW0??
Old Sep 29, 2002 | 04:03 AM
primoEF's Avatar
Default Whats the difference between PR3 & PW0??
Anyone knows? Thx.
Old Sep 29, 2002 | 10:41 AM
primoEF's Avatar
Default Re: Whats the difference between PR3 & PW0?? (b18k1)
anyone please
Old Sep 29, 2002 | 11:41 AM
HybridFiend's Avatar
There could be a book on this subject. You should tell what you know to save other's time telling not needed info.
Old Sep 29, 2002 | 01:38 PM
Fishcat37's Avatar
Default Re: Whats the difference between PR3 & PW0?? (HybridFiend)
well- to start off- the PR3 ECU was in the JDM EF8 CR-X SiR and the EF9 Civic SiR. Only came in manual trans. The PW0 ECU was out of the JDM DA6/8 Integra XSi/RSi. It came in auto or manual trans. The PR3 has a revlimiter/fuel cut off at 8200rpms, and I believe that the MT PW0 is the same. The AT PW0's revlimiter is early... between 7400 and 7800 rpms. Both have a speed governor at 112mph. Is that the info that you were looking for?
[Modified by Fishcat37, 10:40 PM 9/29/2002]
Old Sep 29, 2002 | 01:43 PM
primoEF's Avatar
Default Re: Whats the difference between PR3 & PW0?? (Fishcat37)
thats exactly whats I am looking for, I have 2 PW0s and one PR3, when I opened the 2 PW0s, it said "MT" on the smaller circuit board, but when I opened the PR3, it said something different like "AT" on the smaller board, for sure not the same as the other two, PW0 seems to idle better then the PR3, this is why I am asking, thx.
spettinger's Avatar
my b16 pullout has a 1 million (integra) code, with an S1 trans, and a PR3 ecu.... i think both the crx and the integra got the same ecu as i have seen 5 million (crx SIR) pullouts with y1 trans and pr3 ecu. i don't have any idea where pwo's come from. oh well. where in st charles are you?
Old Sep 29, 2002 | 06:31 PM
iwhichisme's Avatar
I do know that pr3's are more readily available for rechipping then pwo's. Otherwise they are quite similar.
peace,
chazz
Old Sep 29, 2002 | 08:53 PM
Sgt_Ox's Avatar
I'll have to say you're wrong on that portion of your post. The PR3 did come in an Automatic trim, because I bought one not knowingly. The rev limiter was hitting alittle passed 7000 RPM's.
Old Sep 29, 2002 | 11:35 PM
bryant's Avatar
Default Re: Whats the difference between PR3 & PW0?? (MrDoHc2)
there are both MAN. and AUTO of both ECU's. but to strainten it out:
PR3 = XSi Integra
PWO = SiR CRX
Old Sep 30, 2002 | 12:10 AM
Gump's Avatar
Default Re: Whats the difference between PR3 & PW0?? (CR-X)
PR3 = XSi Integra
PWO = SiR CRX
my EF9 came with a PWO, but then again, it was reprogramed by spoon, so I don't know if it's the original ECU
Old Sep 30, 2002 | 07:15 AM
SuperCivic's Avatar
Default Re: Whats the difference between PR3 & PW0?? (Gump)
PW0 is the ecu for Civic/CRX SiR 5 million series B16s.
Old Sep 30, 2002 | 09:32 AM
Rob!'s Avatar
Default Re: Whats the difference between PR3 & PW0?? (SuperCivic)
i am about to swap my b16a in and i have a pr3 how can i tell if it is manual or auto?
Old Sep 30, 2002 | 12:48 PM
Phatwhippin_CRX's Avatar
Default Re: Whats the difference between PR3 & PW0?? (RaceFacer)
PR3 = 8200 redline... needs 2 O2 Sensors... Intagra XSi
PW0 = 8000 redline... needs 1 O2 sensor... CRX SiR
Old Sep 30, 2002 | 01:37 PM
Brandon Chun's Avatar
Default Re: Whats the difference between PR3 & PW0?? (Phatwhippin_CRX)
Everything's pretty much been said- one thing though, if you're considering getting some reprogramming done, the pr3 has more programs available I believe, though there are some for the pw0 as well. I've read the auto can only be reprogrammed to 5 speed specs on Locashs site. Other than that looks like yer good to go.
Old Sep 30, 2002 | 03:13 PM
bryant's Avatar
Default Re: Whats the difference between PR3 & PW0?? (Brandon Chun)
There are A LOT of programs for PR3's the PWO has about 2-3
Old Oct 11, 2002 | 05:26 PM
Norcalstoppy's Avatar
They both came in Manual and Auto. I know because I have auto right now with vtec at 4400 and fuel cut at 7600.
Jay Kim
nousername
Mar 31, 2021 12:49 PM
dand39
Oct 12, 2003 10:38 AM
00VTEC
Aug 7, 2002 08:42 AM
02WRX
Jun 10, 2002 01:18 PM
ricodemus
Apr 22, 2002 11:25 PM
