bad hesitation probelms with my b16a...HeLp!
Old Sep 29, 2002 | 02:47 AM
enhancedCL9's Avatar
Default bad hesitation probelms with my b16a...HeLp!
Okie i've change a couple of things so far but the hesitation is still there.
Distributor.
throttle body including sensor.
fuel injectors.
hesitation starts when the motor is warmed up but when it's cold it runs perfect!
It struggles on the freeway barly hitting 60mph in 5th gear so i gottah down shift to 4th gear to bring it up. Sometimes it goes away for a second and then comes back.
The weird thing is that it doesn't throw any codes and also no check engine light!
Please help out anyone?
[Modified by thizguy, 11:49 AM 9/29/2002]
Old Sep 29, 2002 | 03:20 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: bad hesitation probelms with my b16a...HeLp! (thizguy)
you ever see the throttle cable?
Old Sep 29, 2002 | 03:47 AM
Stupid Ass's Avatar
Sounds like your dizzy is acting wierd... change the cap and rotor, put some new plugs and plug wires in and then see whats going on...
Old Sep 29, 2002 | 05:11 AM
JALOP B16's Avatar
1. Check your cat coverter/ and o2 sensor
2. check your fuel filter
3 Check your coil (Why the hell do people forget these go out? )
4. intectors cloged?
Old Sep 29, 2002 | 09:19 AM
91HATCH's Avatar
Default Re: bad hesitation probelms with my b16a...HeLp! (JALOP B16)
try swaping the o2s around....
Old Sep 29, 2002 | 02:30 PM
Default Re: bad hesitation probelms with my b16a...HeLp! (SOHC NoTEC)
yeah, i've already change spark plugs, spark plug wires, cap and rotor?
i'm confused. But imma check the o2 sensors? Does it really do a differents when you switch them around? Cause some people say it can be backwards?
Thanx!!!
Old Sep 29, 2002 | 03:24 PM
spcmotorsports's Avatar
have your tps checked when my went bad it , i would have to like pump it then it would be good hondas are known for tps and icv.
Old Sep 29, 2002 | 06:25 PM
iwhichisme's Avatar
IF youre running two o2 sensors then you probably need to switch them both. I had the same problem when i did a b16 swap a while ago. If not that then check your ignitor, and timing.
peace,
chazz
Old Sep 29, 2002 | 07:26 PM
Default Re: bad hesitation probelms with my b16a...HeLp! (iwhichisme)
you mean get new ones or switch them around?
Old Sep 29, 2002 | 08:45 PM
MADEINIRAQ's Avatar
i had same problem. switch pin C8 and C16 on the ecu should take about 10 minutes start to finish
Old Sep 29, 2002 | 08:54 PM
customx_'s Avatar
New User
Default Re: bad hesitation probelms with my b16a...HeLp! (madeiniraq)
Old Sep 29, 2002 | 10:15 PM
twincamrex's Avatar
Default Re: bad hesitation probelms with my b16a...HeLp! (mindtrix)
Can anyone explain how to do this.. do you need a special tool to get the pins out? thanks in advance
Old Sep 29, 2002 | 10:57 PM
Default Re: bad hesitation probelms with my b16a...HeLp! (twincamrex)
yeah do you need a tooL?
Old Oct 1, 2002 | 12:26 AM
Anyone????????
Old Nov 27, 2002 | 09:30 PM
turtleb16a's Avatar
ok, im pretty pissed off.... tried taking pin 8 out in 3 minutes.... pin 16 took 2 hours and it still won't come off... am i doing something wrong? can anyone help with this issue? tried everything.... broke about 10 to 15 pins, auto pics did not work... the pin just did not want to come off... not even sure how the pin 8 came out.
need assistance quick... may go back downstairs for another round but would like to see if there was a special way of inserting the needles, pins or pics..
i thought you guys were full of crap about the 5 to 10 minutes... i thought it would take no more than 30 minutes though...
any assistance appreciated.
Old Nov 27, 2002 | 10:31 PM
turtleb16a's Avatar
Default Re: bad hesitation probelms with my b16a...HeLp! (turtleb16a)
no one can answer this question?
Old Nov 28, 2002 | 12:14 AM
raene's Avatar
You just stick the pin in the hole, lever up the little clip that's holding the ECU pin in place, and pull the pin straight out. They take me like 5 seconds to unclip now (but that's since I got practice, LOL). Don't worry, they're hard to figure out right off the bat but you'll get it
Old Nov 28, 2002 | 07:37 AM
turtleb16a's Avatar
Default Re: bad hesitation probelms with my b16a...HeLp! (raene)
Thanks Raene, what kind of pins did you use? Tried everything, they either snapped or were too big. Any suggestions on what i should use that wont break the pins or damage the molex?
Old Nov 28, 2002 | 08:19 AM
Scarface928-Huey Tran's Avatar
Default Re: bad hesitation probelms with my b16a...HeLp! (SLOW CRX)
Make sure you have some left over or extra pins.(Any old honda harness will work)It takes time.Even if you can't get the pin off perfectly don't worry just make sure you don't break the plastic harness on your car.After you remove it replace it with a perfect pin that you took off earlier off the spare one.Keep removing pins out your spare one and your get the hang of it.Moms small sewing pin works perfectly.Just don't put any bent ones back in so she won't bitch at ya. Happy Turkey day.
Assassinxiv
Mar 28, 2014 10:45 AM
dub from laos family
Apr 16, 2008 11:30 PM
derfzog
Mar 14, 2008 12:12 PM
99blackdc2
Oct 28, 2006 08:40 PM
Spade
Dec 4, 2003 07:11 AM
