gsr still overheating after head gasket change
Old Apr 25, 2011 | 08:10 AM
swisher_13_87's Avatar
Default gsr still overheating after head gasket change
Well I changed my head gasket started getting hot would bubble out the overflow changed it and still doing the same thing has new pump and a mugen thermoswitch and thermostat help...
Old Apr 25, 2011 | 08:12 AM
HEADS OR TAILS's Avatar
Default Re: gsr still overheating after head gasket change
what about the radiator cap??
Old Apr 25, 2011 | 08:25 AM
mouab18c1's Avatar
Is your fan turning on? Is your radiator clogged?
Old Apr 25, 2011 | 08:49 AM
Only has 3k miles shouldn't be clogged but its a new fluidyne rad and cap and a new fan
Old Apr 25, 2011 | 09:15 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If the coolant level rises in the radiator neck while the engine warms up, it means there's air somewhere in the system. The air expands as it heats up and pushes the coolant level higher in the radiator.
Old Apr 25, 2011 | 09:37 AM
bigislandc2's Avatar
when is it overheating? will it overheat just idling or when the vehicle is under a load? what was the reason for headgasket replace?
Old Apr 25, 2011 | 09:52 AM
yea that's what im hoping for that's just what it did before I changed it had a split was leaking compression no.1 cylinder so hopefully it's a one time deal but what if it isn't what should I look into then
Old Apr 25, 2011 | 09:54 AM
it overheats after driving awhile but it does it slowly so only once since the change so I hoping for air in the system to be the culprit just seemed to coincidence that it did the same thing
Old Apr 25, 2011 | 03:23 PM
yea just try to bleed the air out. some motors have a bleeder screw, if not a spill free coolant funnel is nice, but be sure the front of the vehicle is higher then the rest. also try to recheck for the leak on the first place.
does the upper coolant hose become hard after a few minutes
Old Apr 25, 2011 | 03:48 PM
94VTEC2TONE's Avatar
you sure the mugen thermostat isnt faulty? did you install the headgasket properly? did you bleed the top screw for the head, that leads to overheating quite easy. are you using the gauge to register its overheating, gauges can be wrong
Old Apr 25, 2011 | 06:59 PM
when you put the heater on will the temp go down.
Old Apr 26, 2011 | 07:48 AM
Mattb16teg's Avatar
Community Builder
Bleed the system.
Take off the radiator cap and let the engine run, turn on the heat full blast for about 5 - 10 minutes(this will in theory get all the air out of the heater core). Continue letting the car run with the heat turned off now until the radiator fan comes on(assuming your fan and switch and thermo are good).
Old Apr 26, 2011 | 09:27 AM
Community Builder
You don't have to blast the heat in the cabin, just have the temp slider on full hot. Having the slider on hot opens the valve that lets the coolant circulate through the heater core. Turning on the blower does just that, turns on the blower motor, to blow air over the hot heater core. The air blowing will have no effect on the coolant lines or any air that may be in them.
*edit* you should always have the temp slider on full hot before starting any procedure that deals with engine coolant, i.e. coolant flush, or any procedure that requires you to drain the coolant, and likewise keep the slider on hot when you fill the system with coolant at the end of the job.
Old Apr 26, 2011 | 10:59 AM
Thanks guys for all the advice I will re bleed it this weekend hopefully that will fix it
xTomei
14
Jun 23, 2010 02:50 PM
greenleg88
Mar 8, 2009 10:04 AM
spruman03
Honda Civic (2001 - 2005)
Jul 6, 2008 11:40 AM
scoobyghost
17
Jun 14, 2004 11:17 AM
CRXSIR1
Jan 12, 2003 05:53 PM
