diy coilover ek
Old Apr 24, 2011 | 10:56 PM
racerx510's Avatar
Default diy coilover ek
so im looking to build my own setup. i found a place that sells just the coilover springs. i was gonna grab a set of ebay collars and some koni's with extended top hats. wats everyone think?
i was thinking of ksport or apexi springs. its a daily, so im going for comfort
Old Apr 25, 2011 | 12:04 AM
98civdx's Avatar
Master Detailer
Default Re: diy coilover ek
Why not just get Koni/ground control?
Koni shocks are different then stocks. They have a "cir clip' that the sleeve grabs. The Sleeves NEEDS to be koni spec. No names are not.
Old Apr 25, 2011 | 12:18 AM
blackedEk's Avatar
agreed^
koni w/ground control is a good setup
do not buy ebay coilovers
Old Apr 25, 2011 | 03:02 AM
Libertariat's Avatar
Ek Forever y0!
If you want a comfortable daily just get ground controls with the off-the-shelf rates. I can guarantee you ebay or ksport springs are not going to be comfortable.
For some reason a lot of people think springs are comfortable and coilovers are not. Neither is more or less comfortable than the other. It all depends on the spring rate.
Old Apr 25, 2011 | 08:48 AM
that_boy_sammy's Avatar
Don't buy ebay coils, its like they built em and never tested them out because those things break like nothing. Ground Controls, Function & Form, and Eibach are really good.
Old Apr 25, 2011 | 09:34 AM
98ekb16's Avatar
The ebay collars are just as bad as the springs. I've had them break before too.
Old Apr 25, 2011 | 10:51 AM
98civdx's Avatar
Master Detailer
Its becuase they buy low quality parts that typically have very high spring rates and put them on cheap shocks.
Or, they think a 350lb spring is back breaking stiff.
I can't find the thread anymore but there was a guy that had ebay coilovers and the spring rates ended up being 650lb for all 4!
Old Apr 25, 2011 | 11:42 AM
Ek Forever y0!
I find my 350lb front springs to be too soft. My 350lb rear springs do make it a bit rougher on bumps. Rear rates much more often contribute to ride comfort problems than front rates.
Old Apr 25, 2011 | 11:47 AM
ef9_lover's Avatar
grab urself ef fork take them to a machine shop get then make the diameter big enough for ur ek struts to fit inside. automatic 2 inch drop without making ur car drive like **** on ebay coils.
98civdx's Avatar
Master Detailer
Yes, my 350lb rears deffinetly make it a little harsh, and not as comfy as I would like sometimes, however they deffinetly are not that stiff.
Old Apr 25, 2011 | 12:29 PM
blackedEk's Avatar
haha good one
My JDM EJ8
Suspension & Brakes
Dec 1, 2008 02:46 AM
4Dinsaneb16
May 11, 2007 01:35 PM
Innocent_Bystander
Suspension & Brakes
Jan 12, 2006 10:52 AM
I6turbo
Suspension & Brakes
21
Feb 25, 2005 12:27 PM
