bw S366 outlet vband size?
Old Apr 24, 2011 | 06:53 PM
turboman2.2's Avatar
Default bw S366 outlet vband size?
I have a 83 ar t4 outlet s366. I was wondering what size vband this is. I measured the outlet diamter at 3.25 and the size of the flange at 4.25. Do i use a standard 3.25 flange? I have read somwhere that you can use a standerd 3.5 vband flange and clamp. I dont know what to order.
Old Apr 24, 2011 | 07:44 PM
TheShodan's Avatar
Moderator
Default Re: bw S366 outlet vband size?
You can't just get the 3.25" v-band flange because it is set at a different angle than Garrett or Precision. The S366 w/ the T4 outlet is a John Deere part originally. You need to contact Bullseye Power, as they have that v-band clamp & Flange available for that size.
http://www.bullseyepower.com/contactus.asp
Talk to Dave H. or Bill Devine
Old Apr 25, 2011 | 11:07 AM
ScorpionT's Avatar
Its a 4.21" V band.
Old Apr 25, 2011 | 05:32 PM
b00sted EK's Avatar
i have a bep s366 with a .91 turbine. what i did was weld a 3" v-bang flange onto the tubine flange.
Old Apr 28, 2011 | 09:20 PM
faeflora's Avatar
Boner. I have a 366 in my hands right now and I need a weld on flange for my downpipe. Argh. Where is John Deere when I need him?
Old Apr 28, 2011 | 09:31 PM
TheShodan's Avatar
Moderator
Order these from a John Deere Dealer
Special T-bolt clamp - Part # RE40048
Weld flange (80mm) - Part # R87732
You're welcome ;-)
Old May 2, 2011 | 08:19 AM
I went to a turbo diesel supply shop, they gave me the right flange and clamp. Cost me like 30 bucks for both.
Old May 7, 2011 | 03:14 PM
faeflora's Avatar
You're welcome ;-)
Holy frikken shizmofrakk
How the hell did you find this information? Thank you!
I also found them here:
http://racepartsolutions.com/proddet...FLANGE&cat=102
Old May 7, 2011 | 03:16 PM
faeflora's Avatar
Wow we are all running the same turbo. Awesome!
What are everyone's power goals?
I have a 1.9L miata. Only 4 other people have run turbos this large on Miatas before so I'm not sure how much power to expect. I'm guessing 25psi will get me to 580hp, 30psi 630hp? Dunno.
Old May 7, 2011 | 04:50 PM
TheShodan's Avatar
Moderator
Miata cylinder heads are much different than honda B-series, despite similarities in displacement size. Time to just go to the dyno, get it calibrated and find out, at this point. Guesstimating just seems to give people false hopes.
bryse68
Apr 28, 2009 01:15 PM
airwalk07143
Mar 24, 2009 06:17 PM
fidget15
Welding / Fabrication
Feb 7, 2009 10:17 AM
EVIL_AWD
Oct 24, 2004 06:47 PM
