b20b swap in 95 hatch, compression and leakage doesn't make sence
Old Apr 24, 2011 | 05:41 PM
j4s0n1337's Avatar
Default b20b swap in 95 hatch, compression and leakage doesn't make sence
When I do a compression test I get 150 across the board, if I drop oil in the spark plug hole I get 200+, leakage is 50% across the board with air coming out of the throttle body. I already replaced the valve seals, I'm thinking it's the piston rings because of the compression test results, but I wanted to be 100% before I drop the cash on em. And before you say anything, YES IT'S AT TDC, I QUADRUPLE CHECKED!
66fasty
May 7, 2008 12:50 PM
92siracer
Jun 2, 2004 10:29 PM
EF8_SiR
Jul 20, 2003 10:24 PM
Hybrid Boy
Aug 28, 2002 03:09 PM
