ls/vtec turbo clutch slip
hi guys, the car was running great but start leak at the slave cyl, just replace the slave and now when hit boost start slipping to redline. The pedal
feel's with pressure run's great whitout boost, the clutch feel's good from the
first bleed.
any help
thanks
first bleed.
any help
thanks
333whp/221tq 14.5 psi street tune. But the car was running great for the last
months. Maybe a bad slave is not OEM is from a local auto parts.
really not i just change the slave, but now that you mention the pedal is a
little more soft. I'll try to buy a new slave and if not work change the master.
your pedal may have been over adjusted because there may have been air in the system before hand
now that you replaced the slave and properly bled the system of air, the overadjusted pedal might not fully release the clutch
this is just a guess though
Mike banX
10
Feb 16, 2011 01:12 PM
