B20 build with new rings, should I hone or not?
Old Apr 24, 2011 | 11:13 AM
stocky's Avatar
Default B20 build with new rings, should I hone or not?
Im building a b20b block for a b20vtec build. New rings and pistons are going in. Should I hone the block before the pistons are seated?
The Helms manual says "Only scored or scratched cylinder walls must be honed".
Old Apr 24, 2011 | 11:15 AM
93supercoupe's Avatar
Default Re: B20 build with new rings, should I hone or not?
of course you hone them, it gives the new rings a new surface to become friends with.
Old Apr 24, 2011 | 11:43 AM
N/A's Avatar
N/A
Purpose Built
While having the chance its good to hone the cylinders. Whether you "need" it or not, you want the lease blowby
Old Apr 24, 2011 | 06:58 PM
Alaniz's Avatar
Tell the machine shop to just bump the cylinders for new rings and they should know what theat means. If after market stock size pistons are used Arias/JE etc... then tell them to power hone. Im a machinist and thats what I would recommend.
Alaniz Technologies
Old Apr 24, 2011 | 07:09 PM
N/A's Avatar
N/A
Purpose Built
Robban26
15
Jan 24, 2004 01:31 AM
Propulsion
Sep 28, 2003 12:21 PM
xteg95
May 3, 2003 04:16 PM
xteg95
May 3, 2003 10:56 AM
SupaFly_Honda
Jan 21, 2003 06:53 AM
