civic cel code 09
hi all.
i have a 94 civic ex thats giving me a cel of 09. its the cylinder sensor. i research it and people said its the dist. is that correct? thanks for the help.
It could be a bad CYL sensor in the distributor, a bad wire, or even a bad ECU.
Does code 9 return after you reset the ECU? If so, have you measured the resistance of the CYL sensor?
N1NjA TuRtLE
12
Jun 5, 2004 08:30 PM
